Vote for Tractor of the Month
? About A Briggs And Stratton Engine
6 replies to this topic
#1 Kyocum OFFLINE
Kyocum
  • 282 Thanks
  • 406 posts
Posted March 30, 2013 - 07:21 AM
Morning all I just was givin a 18hp  B&S engine that came off a Craftsman GT. Problem is the wiring is a mess. I have the Model Type and Serial #,s would that help identify which machine it was born with to help come up with a wiring diagram.
1. Model # 442437
2. Type  #0721 01
3. Code 86041712
The engine was givin to a friend of mine because it was suppose to have been blown up. Come to find out the ring gear on the starter was broken and wedged into the starter not letting it rotate. I was givin the motor because my friend is having some family issues he is trying to work through and doesn't have a lot of time for GT's anymore. My plan is to try and morph this thing into a 1711 Cub Cadet for yard duty. Any help will be highly appreciated. Thanks in advance. Kelly
#2 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,520 Thanks
  • 4,038 posts
Posted March 30, 2013 - 07:44 AM
Hi Kelly, have a look at the B&S homepage
maybe this can help a lil Attached File  Briggs Wiring Diagrams.pdf   771.05KB   25 downloads
Edited by jd.rasentrac, March 30, 2013 - 07:58 AM.
  • Kyocum said thank you
#3 KennyP ONLINE
  • 29,535 Thanks
  • 40,518 posts
Posted March 30, 2013 - 08:07 AM
This manual may be very close. Wiring is shown on page 26 & 27. The engine code is a little off, but close.
#4 Kyocum OFFLINE
Kyocum
  • 282 Thanks
  • 406 posts
Posted March 30, 2013 - 08:46 AM
KennyP I think that will work. Thanks a million.
#5 KennyP ONLINE
  • 29,535 Thanks
  • 40,518 posts
Posted March 30, 2013 - 09:26 AM
You might check in here for more info.
#6 Kyocum OFFLINE
Kyocum
  • 282 Thanks
  • 406 posts
Posted March 30, 2013 - 09:27 AM
This was actually a pretty good haul. The engine has awsome compression and it even came with the electric PTO clutch.
#7 KennyP ONLINE
  • 29,535 Thanks
  • 40,518 posts
Posted March 30, 2013 - 09:31 AM
I have 2 of those. One needs a rod, possibly a crank. Other could use an overhaul, has a slight knock.
