I Finally Fixed The Sidewall Problem On My Trailer!
15 replies to this topic
#1 Ryan313 OFFLINE
  • 3,403 Thanks
  • 5,240 posts
Posted March 29, 2013 - 07:13 PM
Some may remember that after I made the wheels (HERE) for my my trailer, one tire was hitting the side of the trailer since these tires are wider then the ones that where on it before. I do not use it much, if any, in the winter so I put it off until warmer weather. Warmer weather is here and I have been using it quite a bit lately, so I decided to fix it.
I used my grinder and made a cut in one leg of the angle iron, then I cut halfway through the other leg so I could bend it without heat, I am out of acetylene.
90033CC6-7CFE-436F-B141-1B6B17AF679E-615
Once they where bent in, I made a small bevel and welded the cuts back in. Under the fresh welds, you can see the welds I made when I built the trailer; the welds from today are not my best, and have a lot of undercut, bu I have come a long way!
C0A4F366-9A72-4D63-A07E-498AC8EB61A0-615
The side now clears the tire. I thought that the sidewall of the tire would have been worn down, but there was actually a good size groove in the wooden side of the trailer instead! The pressure on the side of the tire put a good amount of wear on the bearings, but I was able to tighten them up no problem.
Here is a picture from last summer, for those who may not know what the trailer looks like.
  • Gtractor, MH81, hamman and 5 others have said thanks
#2 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted March 29, 2013 - 07:56 PM
Great work Ryan, but where are you hiding the tire clearance before and after pics lol.
  • Ryan313, WNYTractorTinkerer and larryd have said thanks
#3 Gtractor ONLINE
Gtractor
    the homeless tractor hoarder
  • 9,632 Thanks
  • 5,042 posts
Posted March 29, 2013 - 08:02 PM
Looks like a great weld to me!  :thumbs:
  • Craig., Ryan313 and larryd have said thanks
#4 Ryan313 OFFLINE
  • 3,403 Thanks
  • 5,240 posts
Posted March 29, 2013 - 08:07 PM
Sorry Casey, I forgot to take an after picture; I will get one tomorrow and add them.
  • larryd said thank you
#5 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted March 29, 2013 - 08:09 PM
You were just drooling over that weld so much that you got lazy with the camera lol.
  • Ryan313 and larryd have said thanks
#6 MH81 OFFLINE
Posted March 29, 2013 - 08:11 PM
Trailer is looking much better Ryan.
#7 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted March 29, 2013 - 08:15 PM
Looks like a decent weld to me, too.
That trailer looks like a great match for your Power King.
Ben W.
#8 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted March 29, 2013 - 08:19 PM
First off that is a beautiful piece of property and the weld will hold up thru any storm-I woldn't worry about it, it does look good.
Dick
#9 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted March 29, 2013 - 08:38 PM
your welding has imporved with time and practice keep up the good work and weld on my friend
#10 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted March 29, 2013 - 08:39 PM
Looks like a heavy duty trailer.
#11 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted March 29, 2013 - 09:13 PM
That came out great Ryan! :thumbs:
#12 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted March 29, 2013 - 11:29 PM
That weld looks good to me and they keep telling me I can't see .
larryd
  • Ryan313 said thank you
#13 KennyP ONLINE
  • 40,032 Thanks
  • 46,727 posts
Posted March 30, 2013 - 05:41 AM
That was a good way to fix that, Ryan. Looks good to me!
#14 Ryan313 OFFLINE
  • 3,403 Thanks
  • 5,240 posts
Posted April 04, 2013 - 08:19 PM
The other day I put some paint on the bare spots. I do not have any mre of the paint I used when I painted the trailer, so I used caution red. It did not come out great; I could not find a brush, so I used a rag. :D
0C2E6D35-BC48-49B7-A195-2F1F43C9DA9F-113
Edited by Ryan313, April 04, 2013 - 08:19 PM.
#15 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted April 05, 2013 - 08:31 PM
whats it matter what it lloks like as long as the bare steel is covered up so it doesnt start growing rust
