What's That - The Tiller Version
14 replies to this topic
#1 twostep OFFLINE
twostep
    Rockstar
  • 1,983 Thanks
  • 2,534 posts
Posted March 28, 2013 - 07:32 PM
Can anyone ID this tiller? The tin is 40" side to side. I know the front cat1 arms were added as well as the bastard PTO shaft. But WHAT is the main tiller portion???
3K73M63H95G55F55H6d3re38e97fecb191468.jpg 3Kb3G53M65I35F35Mdd3rb44b7d0e7117155c.jpg 3M93Jd3Hc5Ib5L35J3d3ra3bf105b6fc014ee.jpg
  • boyscout862 and Huskyfan have said thanks
#2 twostep OFFLINE
twostep
    Rockstar
  • 1,983 Thanks
  • 2,534 posts
Posted March 28, 2013 - 07:42 PM
I'll follow up to my own question... Based on this thread by ggsteve on MTF it is a Bolens tiller: http://www.mytractor...ad.php?t=212999
#3 Bolens 1000 OFFLINE
  • 14,978 Thanks
  • 18,136 posts
Posted March 28, 2013 - 07:45 PM
Yep, It was originally a Bolens but has been Hacked up pretty good....
  • twostep said thank you
#4 twostep OFFLINE
twostep
    Rockstar
  • 1,983 Thanks
  • 2,534 posts
Posted March 28, 2013 - 08:05 PM
Do you have any idea what it started as and what size tractor it was for? the tin appears to original but it doesn't have an extention to make it the 40" width.
#5 boyscout862 ONLINE
  • 12,818 Thanks
  • 9,153 posts
Posted March 28, 2013 - 10:57 PM
It looks like its for a large frame. One way to tell is which direction you have to turn the pto shaft. Do you own it?
  • twostep and Huskyfan have said thanks
#6 twostep OFFLINE
twostep
    Rockstar
  • 1,983 Thanks
  • 2,534 posts
Posted March 29, 2013 - 12:18 AM
Not yet. I've got a trade deal with a guy pending. I would just like to know as much as I can about it before I go. I plan to use it behind my Kubota. The CO says he took it on trade and used it but it's too small for his tractor.
I don't mind the hacked mounts and shaft since I will likely modify them to fit the Kubota's 3pt anyway.
So which turns which way?
#7 boyscout862 ONLINE
  • 12,818 Thanks
  • 9,153 posts
Posted March 29, 2013 - 07:11 AM
I don't remember which is which. Download this guide http://groups.yahoo....tachment Guide/  and check the model number of the tiller. Good Luck, Rick
We have some of these files in our manuals section but they are separated files by tractor size.
Edited by boyscout862, March 29, 2013 - 07:17 AM.
#8 twostep OFFLINE
twostep
    Rockstar
  • 1,983 Thanks
  • 2,534 posts
Posted March 31, 2013 - 09:30 PM
My tractor's PTO rotates clockwise which is standard for tractors here. I called up the seller and got him to check and sure enough the tiller is a CCW tiller. So the only way to use it would be if I could flip the tines and use it as a reverse rotating tiller.
Anyone have any advice?
#9 wilberj ONLINE
wilberj
  • 5,003 Thanks
  • 5,595 posts
Posted March 31, 2013 - 09:37 PM
Its not a large frame tiller.
#10 twostep OFFLINE
twostep
    Rockstar
  • 1,983 Thanks
  • 2,534 posts
Posted March 31, 2013 - 10:21 PM
Do you know if it is possible to use this gear box in reverse rotation?
  • Huskyfan said thank you
#11 wilberj ONLINE
wilberj
  • 5,003 Thanks
  • 5,595 posts
Posted March 31, 2013 - 10:43 PM
I would think not.....
#12 twostep OFFLINE
twostep
    Rockstar
  • 1,983 Thanks
  • 2,534 posts
Posted April 17, 2013 - 10:41 AM
I passed on this and he never has gottenback to me about flipping the tines anyway... I'm glad too because for the same money I found a Kubota 36" 3pt PTO driven tiller and made a deal this morning. I hope to have it in dirt as soon as it dries out enough.
#13 twostep OFFLINE
twostep
    Rockstar
  • 1,983 Thanks
  • 2,534 posts
Posted April 30, 2013 - 08:34 AM
In case everyone hasn't seen the "what did you do WITH" thread... I got the Kubota tiller that is a matched tiller for my old B5100. The rear half of the tillers PTO shaft was shot and it also has some strange female spline that no one had ever seen before. The seller gave me half of another PTO shaft and with a yoke and Ujoint I was able to get it going. After testing it out I chained the chain box and gear box oils. She should be ready to do some work now.
  • Jordan9682 said thank you
#14 twostep OFFLINE
twostep
    Rockstar
  • 1,983 Thanks
  • 2,534 posts
Posted April 30, 2013 - 08:44 AM
Oh, I forgot to mention that I did two passes in the garden and it did a great job!
  • Huskyfan and Jordan9682 have said thanks
#15 Oo-v-oO OFFLINE
Oo-v-oO
  • 341 Thanks
  • 448 posts
Posted June 23, 2013 - 10:53 AM
That original tiller might have been for a MTD 990 - they look very much like a Bolens. The tinwork and remnants of the mounts are a dead ringer for a 990 tiller.
As for rotation, though - the MTD would have CW facing the tiller input shaft, so in that case I'm not sure. Or is that correct for a CW PTO? Depends on which way you're looking at it.
