Briggs 3 1/2 Hp Carb On A 5 Hp Motor
6 replies to this topic
#1 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted March 28, 2013 - 01:35 PM
Will the carb and tank from a 3 1/2 HP Briggs work on a 5 HP motor?
#2 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted March 28, 2013 - 02:22 PM
What engine numbers do we have?  Vertical or horizontal?
Ben W.
#3 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted March 28, 2013 - 02:30 PM
There both horizontal shaft. The carbs tank and controls look the same.
#4 boyscout862 ONLINE
  • 12,861 Thanks
  • 9,174 posts
Posted March 28, 2013 - 03:35 PM
I think the 3 1/2 is alittle smaller when you try to bolt it up. Atleast on the older ones. Good Luck, Rick
#5 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Without looking, without knowing, I'd venture a yes they might.
If its a suction carburetor (diaphragm to pump fuel, mounted directly on the tank) then they are probably identical.  If it is a Briggs float type, we're back to "they might" again.
I'd take the model-type-code and plug them into the Briggs website and check the IPL's.
Ben W.
#6 bowtiebutler956 OFFLINE
bowtiebutler956
  • 660 Thanks
  • 796 posts
Posted March 28, 2013 - 04:41 PM
 Yes, the 3-5hp engines used the same carb.
Matt
  • Amigatec said thank you
#7 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted March 29, 2013 - 01:29 AM
I'll post the number this weekend, the 3.5 HP is a 1995 and the 5 HP is a 1998 model.
