Bought A Hoe......roto That Is.
33 replies to this topic
#1 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,026 Thanks
  • 3,172 posts
Posted March 28, 2013 - 01:02 PM
I plan to mont this on the back of my CC129.
I'm trying to upload more pictures but it says upload failed.
Ok I think I have figured out the problem with the uploads.
If I try to use the bulk uploader it will fail, if I upload at least one using the basic uploader and then switch to the bulk uploader it works.
Edited by Amigatec, March 28, 2013 - 06:06 PM.
  • daytime dave, KennyP and boyscout862 have said thanks
#2 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted March 28, 2013 - 01:03 PM
Hummmmm.....the pictures are upside down, at least it's easy to clean out that way.
#3 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted March 28, 2013 - 01:08 PM
Sorry Ill turn the gravity back on, I had it off for an experiment...
Looks like a good score!
  • superaben said thank you
#4 daytime dave ONLINE
  • 4,963 Thanks
  • 6,597 posts
Posted March 28, 2013 - 01:15 PM
Yes, even upside down, it looks like it's in great shape.  Congratulations.
#5 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted March 28, 2013 - 01:33 PM
The knives need to be changed and 2 of them are missing. I think I can buy knives for it. I have seen something similar at the TSC. I think it will fit the back of the cub nicely.
#6 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted March 28, 2013 - 02:25 PM
Looks good!
Ben W.
#7 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted March 28, 2013 - 02:29 PM
For right now I plan to mount a 5 HP Briggs on it, it's an extra motor. I have another 5 HP Briggs that needs a carb, I may rob the carb and tank from this motor, and use it on the other motor.
I'll stop by Atwoods tonight on the way home and check on some knives and a idler for it.
#8 boyscout862 OFFLINE
  • 13,552 Thanks
  • 9,427 posts
Posted March 28, 2013 - 03:29 PM
I have one similar but a rock was dropped in it and bent the main shaft. I will straightened the shaft now that I have a press. The teeth on some of these are reversible. Just unbolt and turn over, then rebolt. Good Luck, Rick
#9 KennyP OFFLINE
  • 40,899 Thanks
  • 47,099 posts
Posted March 28, 2013 - 04:43 PM
Cool stuff there, Pat! That will be good behind the Cub!
#10 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted March 28, 2013 - 04:53 PM
Hmmmm I'll just have to agree on everyone else's opinions that it looks great. The pictures are not there right now?
#11 KC9KAS OFFLINE
KC9KAS
  • 5,464 Thanks
  • 4,722 posts
Posted March 28, 2013 - 05:11 PM
I don't see anything except the text!
#12 KennyP OFFLINE
  • 40,899 Thanks
  • 47,099 posts
Posted March 28, 2013 - 05:23 PM
Where did they go?  Have we got gremlins at work?
#13 Rock farmer OFFLINE
Rock farmer
  • 1,298 Thanks
  • 1,274 posts
Posted March 28, 2013 - 06:58 PM
I see the pictures! But, let me understand, roto hoe is a roto tiller manufacturer. But, that's a chipper shedder? But, it's not a hammer mill. it's got cutter blades in it? Is it for leaves and small things or does it do branches too?
#14 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted March 28, 2013 - 07:13 PM
It should do branches the shoot on the side is for branches.
I was finally able to reap load the pictures, the first time around they were upside down.
I think I can make new blades fom mower blades, I found some that will work.
#15 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted March 29, 2013 - 02:49 AM
After doing a lot of looking, it appears that there are several different model. I have seen posts of model 500, 500H, 800, and 800H.
I think the number is the HP, I.e. 500=5 HP and 800=8 HP. And the H means Hammer Mill, the one I have is not a hammer mill, it uses knives to cut with. Also the straight blades go on the side where the limbs go in there is a plate bolted to the side on the hopper to help chop off the limbs as you feed them in.
It doesn't look to hard to convert this to a hammer mill, I would need some steel plates, and some blades from a rotary mower.
