Worth The Money?
12 replies to this topic
#1 Trav1s OFFLINE
Trav1s
  • 3,298 Thanks
  • 4,353 posts
Posted March 28, 2013 - 07:59 AM
Vanguard 14 hp v-twin for $225 for a re-power?  Needs carb work and no idea on specs or hours.
Thoughts... beside crank size/style and hours...
  • larryd said thank you
#2 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted March 28, 2013 - 08:03 AM
good motor. if its clean, and taken care of, but not running i would say dont go above 200.  parts tend to be a little pricey
#3 HowardsMF155 OFFLINE
  • 2,861 Thanks
  • 2,987 posts
Posted March 28, 2013 - 08:06 AM
I'd probably jump on it if it came up for sale here.  The only ones I've seen at that price have been basket cases where the owner clearly states there is an issue.  Otherwise, used are starting at $500 and up.
#4 Trav1s OFFLINE
Trav1s
  • 3,298 Thanks
  • 4,353 posts
Here is the note with it:
I have a 14 v twin vanguard for sale. It has electric and pull start it is a horizontal shaft. It does need caberator work it has 90 lbs of compression in both cylinders. The fuel pump works also. I would consider trades or offers.
#5 Cat385B OFFLINE
    HAZMAT CAT
  • 13,967 Thanks
  • 9,999 posts
Posted March 28, 2013 - 08:09 AM
What the heck, it's only money.
  • Trav1s and larryd have said thanks
#6 Trav1s OFFLINE
Trav1s
  • 3,298 Thanks
  • 4,353 posts
Posted March 28, 2013 - 08:15 AM
I am going to call on specs and if it is a tapered crank I will pass.  I want a re-power that will not compromise functionality.
#7 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted March 28, 2013 - 08:44 AM
The seller may not know what is meant by tapered crank.
Dick
#8 Trav1s OFFLINE
Trav1s
  • 3,298 Thanks
  • 4,353 posts
Posted March 28, 2013 - 09:01 AM
I was going to get the "spec" info and figure out that myself.  Prolly true.
#9 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted March 28, 2013 - 11:19 AM
Sounds like a good deal if it has the right crank for you .
larryd
#10 glgrumpy OFFLINE
  • 8,605 Thanks
  • 7,909 posts
Posted March 28, 2013 - 02:40 PM
My 20hp vanguard has a two barrel carb, a Nicci brand import and the kit alone is $80. Non adjustable mains and you need to get specs to have the right main sizes in the kits, there are several. Not sure what smaller hp ones have. many times the fuel pumps are weak on older engines also, makes for lots of cranking before starting. They are just pulse pumps.
#11 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted March 28, 2013 - 04:45 PM
IF it runs , its a steal----new Horiz Vanguard 14 is likely $7-$800? . I'd love to have it.
#12 backwoods ONLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted March 28, 2013 - 05:37 PM
let us know how ya make out on the motor
#13 Trav1s OFFLINE
Trav1s
  • 3,298 Thanks
  • 4,353 posts
Posted March 28, 2013 - 06:01 PM
I will call tomorrow... a bit busy this week.
