Quick Question On Mower Deck
7 replies to this topic
#1 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted March 27, 2013 - 07:29 PM
Will a jd317 deck work on my jd314 ? I'm in the middle of negoiations with a man with a 317 deck Needs blades and a little paint . Has all new bearings Idler spring and pulleyand a mule drive for $150 .I want to be sure before I leap.
larryd
#2 Trav1s ONLINE
Trav1s
  • 3,293 Thanks
  • 4,351 posts
Posted March 27, 2013 - 07:32 PM
Yes it will.  The 120/140/300/312/314/317/316k/316 Onan/318/322/330/332 all take the same decks.  Make sure you get draft arms and the mule drive for the deck you are purchasing.
Sounds fair with the mule included.
  • larryd said thank you
#3 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted March 27, 2013 - 07:38 PM
Travis  Are the draft arms on the 317 different than 314 ?
larryd
#4 Trav1s ONLINE
Trav1s
  • 3,293 Thanks
  • 4,351 posts
Posted March 27, 2013 - 07:48 PM
Arms are tied to the deck and not the tractor.  I know that a model 41 (got one for my 120) takes a different arm than the 48 deck I have for the 314.  Not sure if that answers your question.
Even if you are missing something I would think it would be easy to find what you need for your 314.
Edited by Trav1s, March 27, 2013 - 07:49 PM.
#5 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted March 27, 2013 - 07:54 PM
Thankyou Travis.
larryd
#6 Trav1s ONLINE
Trav1s
  • 3,293 Thanks
  • 4,351 posts
Posted March 27, 2013 - 07:57 PM
You bet!  Let us know how it plays out.  Got me thinking about calling on a $50 314 deck on CL in Omaha...
Edited by Trav1s, March 27, 2013 - 07:58 PM.
#7 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted March 28, 2013 - 07:34 AM
The deck will work but you will need a shorter belt for the 314 as the PTO pulley is lower than on the twin cylinder engine. I think it's 2" lower so a 4" shorter belt is needed. When getting my 49 snow thrower I did some research and found this info. on the JDparts site when looking at drive belt part no's.
  • Trav1s said thank you
#8 Trav1s ONLINE
Trav1s
  • 3,293 Thanks
  • 4,351 posts
Posted March 28, 2013 - 09:02 AM
Brian is right and I forgot about that... belts are impacted by the engine and size of deck.
