Jd 210 A Well Oiled Machine
11 replies to this topic
#1 WHdbJD OFFLINE
WHdbJD
  • 686 Thanks
  • 516 posts
Posted March 27, 2013 - 02:30 PM
I have a JD 210,  year 1978 with the 10 hp Kohler purchased at estate auction last fall.
It had original owners manual which calls for 4 pints (two quarts) of oil.
So I put two quarts in and the dipstick shows overfill.  I looked in the manual
again and noticed that the previous owner had penciled in the margin, "use  1 and 3/4 quarts".
That amount probably would read full on the dipstick.
Sooo....should I go by the manual and ignore the overfill on the dipstick?
Or fill to the full mark on the stick (as the previous owner apparently did) ?
#2 jd.rasentrac ONLINE
jd.rasentrac
  • 4,773 Thanks
  • 4,265 posts
Posted March 27, 2013 - 02:48 PM
In the german JD manual the crankcase has 3 US Pint and the gear 3.5 US Pint  Attached File  210-s29.pdf   267.36KB   115 downloads
  • 14,812 Thanks
  • 15,501 posts
Posted March 27, 2013 - 02:52 PM
Did you happen to check and make sure your manual is for the right year model of 210? Maybe JD had more then one manual for that series.
  • jd.rasentrac said thank you
#4 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted March 27, 2013 - 03:12 PM
I know the 1977 212 with the K301 is 1.75 quarts.
#5 jd.rasentrac ONLINE
jd.rasentrac
  • 4,773 Thanks
  • 4,265 posts
Posted March 27, 2013 - 03:43 PM
The german manual is from 1979 (1979: sn95001M-    ), but I don't believe that there are real big differences in fluid capacities
Edit: I forgot this list... Attached File  John_Deere_CCE_Fluid_Capacities(2007).pdf   81.64KB   32 downloads
Here you'll find differences, as Brian said before.
Edited by jd.rasentrac, March 27, 2013 - 03:54 PM.
#6 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted March 27, 2013 - 04:15 PM
I bet the 1.75 is right, but also check the link below.
http://www.kohlereng...als/landing.htm
#7 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted March 27, 2013 - 04:21 PM
The 200 Series takes 1.5 to 1.75. I would not overfill mine.
#8 Trav1s ONLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted March 27, 2013 - 04:23 PM
I just changed oil in the 314 with the K321 and the Kohler service manual says 2 qts for all K3xx engines and that is what it took.  I just grabbed the 120 service manual and it calls for 1.5 qt in the k301.  Maybe a difference in the oil pan used in different applications?  If you have overfilled that much I would drain some out and check again.
#9 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted March 27, 2013 - 04:38 PM
If you over fill and then run it you will have a mess, just go by what dip stick reads.
Dick
#10 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted March 27, 2013 - 05:09 PM
Dumb question: Is it the correct dipstick for the engine?
  • Texas Deere and Horse and Trav1s have said thanks
#11 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted March 27, 2013 - 10:07 PM
it depens on the oil pan
there are two different one it could have
one is a flat bottom and other is not
the flat bottom holds more oil
Edited by lyall, March 27, 2013 - 10:45 PM.
#12 WHdbJD OFFLINE
WHdbJD
  • 686 Thanks
  • 516 posts
Posted March 29, 2013 - 07:28 PM
Thanks for all the replies!  From all the answers , and the links , I think I should drain a little out and
go with 1.75 quarts like the original owner did.
This is a great site!
