8hp Briggs Cut Away
28 replies to this topic
#1 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted March 27, 2013 - 12:36 PM
Since nobody wanted me to cut up the K181, I brought this into the garage so I could take it apart and make it into a cut away. I will go back out soon and start taking it apart.
698C4E67-69C5-46FD-BA0A-3F2491D5C949-377
  • Bruce Dorsi, BairleaFarm, boyscout862 and 1 other said thanks
#2 SearsYellow OFFLINE
SearsYellow
    Mower Extraordinaire
  • 506 Thanks
  • 595 posts
Posted March 27, 2013 - 01:08 PM
It would have been rough seeing that K Series Kohler be cut apart.
  • Ryan313, superaben and larryd have said thanks
#3 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted March 27, 2013 - 01:29 PM
No..... Not a 8hp Briggs!!!!! Ahhhhhhhhhhh :wallbanging: :bigrofl: :bigrofl: :bigrofl: JK
  • LTD, Ryan313 and larryd have said thanks
#4 SearsYellow OFFLINE
SearsYellow
  • 506 Thanks
  • 595 posts
Posted March 27, 2013 - 01:31 PM
Actually I would prefer a tecumseh be cut than any other motor. If I had a Tecumseh engine I would donate it to the cause but I don't.
  • 8tyman8, Ryan313 and larryd have said thanks
#5 boyscout862 ONLINE
  • 12,849 Thanks
  • 9,170 posts
Posted March 27, 2013 - 02:44 PM
Why are you making a cut away engine?
  • Ryan313 and larryd have said thanks
#6 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted March 27, 2013 - 03:56 PM
I have it all taken apart, expect one valve; one valve had the figure 8, which I was able to get out by just lifting the spring and pushing on it a little. The other one I am going to need a spring compressor to get out.
Here is the inside, all taken apart.
96D65936-B5EF-41FF-B528-1C2E19C87C87-391
Since the back comes off, I only have to make one small hole in the side, to see to see the tappets being pushed up and down.
  • boyscout862 and larryd have said thanks
#7 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted March 27, 2013 - 04:20 PM
This is neat. Looking forward to seeing it when it's done.
Sent from my HTC One VX using Tapatalk 2
#8 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted March 27, 2013 - 04:26 PM
Ok, I feel Better now thats is a common Briggs Model your cutting :thumbs:
#9 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted March 27, 2013 - 04:34 PM
OH NO not a B & S.
Are you planning on palnting it all up even the inside parts, that's a got to.
Dick
#10 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted March 27, 2013 - 04:45 PM
OH NO not a B & S.
Dick
I am not sure what I want to do with the inside yet.
  • larryd said thank you
#11 wilberj ONLINE
wilberj
  • 5,003 Thanks
  • 5,595 posts
Posted March 27, 2013 - 04:50 PM
NO not the briggs!
How mad will you guys be if I cut into the junk wisconsin i have?
  • Ryan313, boyscout862 and larryd have said thanks
#12 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted March 27, 2013 - 04:55 PM
NO not the briggs!
I'm pretty sure its illegal in all 50 States to cut up a Wisconsin......
Last time I checked you'll get 25 years in prison if your caught.....
  • Ryan313, bowtiebutler956 and larryd have said thanks
#13 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted March 28, 2013 - 01:00 PM
I realized that I need the rear cover, to hold the governor, and to keep the crank and cam from just falling out. I cut out a corner of the rear cover.
3F8FE8D2-5FF2-42FB-B67C-2FDF53FB19C8-500
I used a grinder to cut it all, worked pretty well! I will clean up the sharp corners with my rotary tool.
  • MH81, boyscout862 and larryd have said thanks
#14 DougT ONLINE
DougT
    Dog Approved
  • 6,926 Thanks
  • 4,994 posts
Posted March 28, 2013 - 01:46 PM
Ryan, Many, many moons ago, (like 40 plus years worth) there was a seventh grade kid faced with doing a project for the school science fair. Not only was a presentation necessary but it required visual aids to go with it. This was the visual aid the kid made. It's gotten worse for wear over the years. It used to be that the ignition would still produce a spark and had both valves. It wasn't the prettiest thing but it got the job done and earned him an "excellent" award at the local and district levels. It was done with a hand hacksaw and a hand sabre saw with a metal cutting blade.
  • olcowhand, MH81, sacsr and 3 others have said thanks
#15 MH81 OFFLINE
Posted March 28, 2013 - 03:06 PM
They had invented the Internal Combustion Engine back then?
EDIT: Now I understand... the reason you got the "excellent" was; this was a design prototype.
(ducking now)
Looks Good Doug, I see some similarities... Great minds think alike.
