The Miraculous Por 15
13 replies to this topic
#1 HANKG OFFLINE
HANKG
  • 6,203 Thanks
  • 3,382 posts
Posted March 26, 2013 - 07:28 PM
I recently repaired a steering wheel on one of my wheelhorse RJs , it had a 4 inch long chunk missing from the underside where the finger grips are. After a lengthy study of the situation I came upon a product called por 15 im sure alot of you have heard of it, Its a part A/B product. I kneaded it together and made a mold from a good section of the wheel applying oil first so it wouldn't stick to it. I then let
 it dry for a hour,after removing the new formed mold I mixed another batch oiled the inside of the new mold and placed the new batch inside of it. All I had to do was push it up into the void trim the excess from around the repair and boy howdy it came out perfect, very little sanding. thanks HANKG.
  • Gtractor, Texas Deere and Horse, sacsr and 4 others have said thanks
#2 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted March 26, 2013 - 07:32 PM
Sounds great! Will you be posting pictures of the process or results?
#3 Ryan313 ONLINE
  • 3,364 Thanks
  • 5,230 posts
Posted March 26, 2013 - 07:34 PM
Sounds like a good fix that could be used by many of us! I to want to see pictures!
#4 HANKG OFFLINE
HANKG
  • 6,203 Thanks
  • 3,382 posts
Posted March 26, 2013 - 07:44 PM
I WILL FIND THE PICTURE AND POST IT ALONG WITH THE MOLD
  • MH81, Texas Deere and Horse and chris m have said thanks
#5 HANKG OFFLINE
HANKG
  • 6,203 Thanks
  • 3,382 posts
Posted March 26, 2013 - 08:45 PM
  • Texas Deere and Horse, boyscout862 and pigsitter have said thanks
#6 HANKG OFFLINE
HANKG
  • 6,203 Thanks
  • 3,382 posts
Posted March 26, 2013 - 09:18 PM
SORRY FOR THE LOUSY PHOTOGRAPHY  LAST PICTURE IS THE FINISHED REPAIR. THE MOLD DRYS UP LIKE STEEL .
#7 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted March 26, 2013 - 09:43 PM
the por 15 i have heard of is the paint that drys hard as concreate
#8 wilberj ONLINE
wilberj
  • 4,990 Thanks
  • 5,590 posts
Posted March 26, 2013 - 09:45 PM
Do you have pic and d.i. of the wheel it self?
#9 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted March 26, 2013 - 10:01 PM
Well thats something I haven't seen before, repairing steering wheels with paint. I guess if it works why not.  About how thick is the repair?  I don't use that stuff, but hoping it won't crack on you after awhile. Good luck with it! Hope it lasts you a long time!
  • HANKG said thank you
#10 HANKG OFFLINE
HANKG
  • 6,203 Thanks
  • 3,382 posts
Posted March 26, 2013 - 10:07 PM
POR 15  makes a paint on product for permenant rust control but they also make POR 15 two part epoxy putty  www.por15.com click on epoxy putty. Made in Morristown NJ. phone no. 973 887 8007
  • backwoods and Nato77 have said thanks
#11 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted March 26, 2013 - 10:26 PM
Thats some interesting stuff! I'll be keeping it in mind for futire projects.
#12 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted March 27, 2013 - 06:26 AM
Thank you for posting that trick.  It sounds like a good one to keep in the back of your mind!!
Ben W.
#13 pigsitter OFFLINE
pigsitter
    enjoyin the livin part of life!
  • 1,227 Thanks
  • 1,083 posts
Posted March 27, 2013 - 08:59 AM
I've seen their products advertised for years but this is the first time I've seen the real world results,looks to be good stuff!
Thanks for sharing your results with us!
#14 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted March 27, 2013 - 09:16 AM
They make many different products, as mentioned. I have a friend that had used it inside of a gas tank of his motorcycle as instructed. About a year ago the coating started coming off in sheets and caused him big time head aches in the gas system. After much money trying to find the cause of the problem of running poorly and many other items purchased he ended up replacing the gas tank. So I often wonder how good of a product is it.
Dick
