Briggs Head Gasket
9 replies to this topic
#1 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted March 26, 2013 - 07:08 PM
Today I tried to fire up the '64 PK to stretch its legs a bit. It did not start so I went to get my plug wrench and when I went to take the plug out I noticed that there was a whole bunch of oil draining down the back of the block! The head gasket is obviously way blown. I don't know what its shape is, and I dont want to take it apart, then have it sit apart while I wait for a head gasket to arrive. Could somebody post a picture of a head gasket so I know better what to look for? It is a model 23.
#2 chris m ONLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted March 26, 2013 - 07:39 PM
It will look similar to the one you took off the K-181, but with a bolt pattern to match the head bolts on your Briggs model 23 :D
#3 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted March 27, 2013 - 03:42 AM
Briggs part #27352 has been superseded to part #692230.
Edited by achomesteader, March 27, 2013 - 05:57 AM.
  • Bruce Dorsi said thank you
#4 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted March 27, 2013 - 04:29 AM
Buying a head gasket just by looking at the shape is dangerous.  Get the numbers off of your engine and take them to where ever you are going to order the gasket.  That's the only true way to get the gasket you need.
  • superaben said thank you
#5 bhts OFFLINE
bhts
  • 1,472 Thanks
  • 2,165 posts
Posted March 27, 2013 - 08:38 AM
Why not just order a new gasket from me when you get the steering wheel. A lot safer then guessing at it.
#6 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted March 27, 2013 - 08:41 AM
Bob, if you could on me the price, that would be great.
The ID tag on the engine is missing.
#7 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted March 27, 2013 - 09:05 AM
This is a briggs.  The numbers are stamped into the sheet metal, no tags.  They are very hard to see at times but if you take a little time and a good light, you should be able to find them.  You may have to remove some dirt or even paint to see them but they are there.  I don't have a 23 so I can't tell you exactly where to look.  I've seen them a couple different places.
  • Ryan313 said thank you
#8 bhts OFFLINE
bhts
  • 1,472 Thanks
  • 2,165 posts
Posted March 27, 2013 - 09:34 AM
PM Sent
#9 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted March 28, 2013 - 06:02 AM
If you have a Model 23 Briggs, you should find the numbers stamped into a nameplate attached to the engine cylinder shield.
Here's one from a Model 23FB
#10 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted March 28, 2013 - 12:54 PM
That is the plate I said was missing. I also looked for numbers stamped in the shroud and found nothing.
