Fixing Up The Power Ho
40 replies to this topic
#1 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted March 26, 2013 - 01:04 PM
Back in Dec. I decided it was time to start on restoring one of my Power Hoes. I tell you time has not been on my side. With trying to get paint to match and parts for the engine its taking awhile.
I got this one almost a year ago for a good price. But after got it home and started to look at it I realized it wasn't in as good a shape I thought.
Got it running with new points and a codensor. The carb needed to be rebuilt and it smoked a bit. Tore it apart and just needed to replace the rings. Everything else looked good, was happy about that.
Someone at some point decided the set screws in the pulley on the output shaft weren't doing a good enough job and put a hose with a hose clamp on the end of the shaft. Doing that the pulley wobbled around and wore the pulley and shaft goofy. :mad2:  I ended up getting one from a fellow member (Thanks Matt) that was in great shape. I haven't decided what to do about the pulley yet. Was thinking about making one out of aluminum, but haven't found a big enough chunk of aluminum to machine down.
The last few weeks I have been cleaning and painting some parts in my spare time.
 Started putting it together last night, but still waiting for a seal and filter screen for the sediment bowl.
Power Ho.JPG Power Ho 1.JPG Power Ho 2.jpg Power Ho 3.jpg Power Ho 6.jpg Power Ho 5.jpg
I'm really happy with the way its turning out. Hopefully this next week (when it warms up a bit) I'll get the chassis sandblasted so I can get it painted and mount the engine. I want to hear it run pretty bad!
  • Bolens 1000, jdslednut, daytime dave and 3 others have said thanks
#2 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted March 26, 2013 - 02:37 PM
Looking good, Nate.  I'm looking forward to the finished project!  Is that an NPR6 or a later clone?
Ben W.
  • Nato77 said thank you
#3 Bolens 1000 ONLINE
  • 15,440 Thanks
  • 18,288 posts
Posted March 26, 2013 - 03:30 PM
Looking Good :thumbs:
#4 daytime dave OFFLINE
  • 4,967 Thanks
  • 6,598 posts
Posted March 26, 2013 - 05:00 PM
Nate it's really shaping up nicely.
This line "But after got it home and started to look at it I realized it wasn't in as good a shape I thought."  really made me laugh.   I have said that to myself more than once.  I'll bet we aren't the only ones either.  lol
  • Nato77 and SamMC have said thanks
#5 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted March 26, 2013 - 05:21 PM
It is a 1947 NPR6.
Ben W.
#6 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted March 26, 2013 - 08:36 PM
That's looking real nice. What shade of green is that?
#7 Alc ONLINE
  • 7,257 Thanks
  • 7,595 posts
Posted March 26, 2013 - 08:49 PM
Looks like it will  be a pretty nice machine when your done :thumbs:
Edited by Alc, March 26, 2013 - 08:50 PM.
#8 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
That looks great! Good luck getting the frame blasted!
#9 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted March 26, 2013 - 09:50 PM
Did a camera shot of the chassis and it came up with PPG 920570 Sherwin Williams Equipment Green. Under the floresent lights it looks way to bright, but if you go outside it looks like more of a drab green thats close to the original.
#10 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted March 28, 2013 - 04:42 PM
I made a little time today to do some blasting. Got the chassis cleaned up and kept having to do spots I missed. Sure is alot of nooks and crannies to get at.
Also blasted around the holes someone put in the rims to mount weights. If they would have drilled them straight across I would've left them.
  • bowtiebutler956 said thank you
#11 Bolens 1000 ONLINE
  • 15,440 Thanks
  • 18,288 posts
Posted March 28, 2013 - 05:20 PM
Looks like your making good progress!
If I were you I'd pull that idler as I'm certain you got some sand into the bearing, That sand finds its way into the smallest space (Learned That the hard way on my first refurbish)
#12 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted March 28, 2013 - 07:26 PM
It has a brass bushing in it, but I was planning on removing it for painting behind it. I might pull a few other things off to get at areas better. You can get at alot more areas with a sandblaster than with a paint gun.
  • Bolens 1000 said thank you
#13 bowtiebutler956 OFFLINE
bowtiebutler956
  • 669 Thanks
  • 796 posts
Posted March 30, 2013 - 09:45 PM
 I just saw this thread Nate, and I got to say your doing a beautiful job. I love the engine! :rocker2:  After seeing the condition of your bench, I've come to the conclusion that we must be related! :bigrofl: The pulley your needing for it, is it the one that is in the pic below from on my 46 NPR6? I was at my local Johnny's True Value hardware the other day, and it looked like they carried pulleys of this same design, or very similar. If you'd like, I can take my pulley there with me, and see if they carry what you need on Mon or Teus. I'll be following this thread!
Matt
#14 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted March 31, 2013 - 01:48 PM
This is the pulley that I need. The smaller is about 3 1/2" and the larger is 7 1/4" ish. It didn't come with the Power Ho, it came with the sickle or reel mower attachment.
#15 bowtiebutler956 OFFLINE
bowtiebutler956
  • 669 Thanks
  • 796 posts
Posted March 31, 2013 - 02:49 PM
 Now I understand why its difficult to find. I'll keep an eye out for one.
Matt
