Hydraulics Off A Hydrostatic Drive
hydrostatic drive hydraulics custom hydraulics modified hydraulics
14 replies to this topic
#1 MiketheHeadlessChicken OFFLINE
  • 1 Thanks
  • 1 posts
Posted March 25, 2013 - 10:08 PM
I have a 1985 Kubota G4200 H, it is a fuel sippin 2 cyl diesel. It came with nothing, learned in New England there isn't much used Kubota attachments for it, BUT I am holding out hope that I can use the Hydrostatic transmission to get a hydraulic lift for a custom 3 point hitch assembly and run some ground engagement attachments, skid some logs, make the most of this tractor...
When I posted on Google, How can I run hydraulics from a Hydrostatic transmission?
It brought me to this forum, there was 5 pages of posts and back and forth between members on this subject, nothing that answered my question though, and most of it was dated and not specific to my Kubota....
So refresh on the question, is it possible for me to get some "live" hydraulics from from tractor, and of so how?
FYI so far I added a custom exhaust as the Kubota dealer wanted $180 for stock. Mine cost me $60, $35 for the muffler and $25 for a custom flange. Savings priceless! Then the fuel pump went...again $100+ from the dealer and I got a 12V universal on Ebay for $16...my engine doesn't know any better....
Looking for practical, utilitarian advice, on what I know to be a complex subject.
  • larryd said thank you
  • 14,468 Thanks
  • 15,392 posts
Posted March 25, 2013 - 10:17 PM
Mike, Welcome to GTtalk, glad you found us.
There will be a few guys come by in a little to answer your question. I'm not up on what Hydro the Kubota uses, but I'm sure like most all the other makes, there is a port to pick up live hydraulics off of.
#3 John@Reliable OFFLINE
John@Reliable
  • 1,295 Thanks
  • 1,416 posts
Posted March 25, 2013 - 10:38 PM
Welcome to GTt,
I looked up the tractor spec's and couldn't fine what I really needed. But with that said, I think you may get a little out of it but not much. If you could get much out of it I'm sure the factory would have done it when new. If you don't plan on using a deck for grass cutting, I'm thinking may be better to just add a hyd. pump and run it off the tractor PTO, plenty of power that way.
P.S. If you get sick of that tractor and it needs a good home let me know, :D
P.S.S. What part of MA?
#4 8tyman8 OFFLINE
8tyman8
  • 414 Thanks
  • 731 posts
Posted March 25, 2013 - 10:41 PM
I think so .... but i am Not sure it all deppends on the Hydro (i think its a eaton 11) but you would have to conferm that your hydro is a 11 how ever the pressure is only 500-800 psi i added hydraulics on my bolens 1256D diesel project ...
http://gardentractor...ens-1256/page-4
And welcome to Gt talk
Best of luck
Cheers
Tyler
Edited by 8tyman8, March 25, 2013 - 10:43 PM.
#5 TUDOR OFFLINE
TUDOR
  • 543 Thanks
  • 497 posts
Posted March 26, 2013 - 03:21 AM
:welcome:
I don't think that it has an Eaton 11 with only 12 hp on tap. At that level, most hydros did not have onboard hydraulics available short of a complete added auxilliary.system.
I added such a system to a MF12H 35 years ago using a GM power steering pump and cylinder and a spool valve set. The pump should be inexpensive, but cylinders and valves can run a bill or two, and hoses can be surprisingly pricey.
You might have some luck on ebay or CL, once you know what parameters you want to deal with.
#6 skyrydr2 OFFLINE
  • 3,625 Thanks
  • 3,277 posts
Posted March 26, 2013 - 03:44 AM
 I never saw an Eaton 11 on a Kubota in my life. All that I have seen had the diesels driving a right angled gear box to a vertical shafted hydro tranny llike the box store stuff... These looked to be a bit heavier ,but not much... and were not really designed for ground engaging attachments. So I don't think it may be possible to tap off your hydro tranny. Your best bet would be a 12 volt pump unit like WheelHorse/Toro used on there 263 series tractors .
#7 KC9KAS ONLINE
KC9KAS
  • 4,969 Thanks
  • 4,398 posts
Posted March 26, 2013 - 04:14 AM
:welcome:
#8 KennyP ONLINE
  • 30,526 Thanks
  • 41,088 posts
Posted March 26, 2013 - 05:17 AM
Welcome to the forum! Good luck with your project.
#9 Alc OFFLINE
  • 5,823 Thanks
  • 6,829 posts
Posted March 26, 2013 - 05:39 AM
Welcome to GTTalk !  Can't help you much except if hyd of your hydro won't work maybe a 12volt linear actuator for the rear lift ?
#10 Arti ONLINE
Arti
  • 1,331 Thanks
  • 977 posts
Posted March 26, 2013 - 07:23 AM
I can't help with the Hydraulics question.. However Welcome to GT Talk
#11 JDBrian OFFLINE
  • 9,592 Thanks
Posted March 26, 2013 - 07:48 AM
Welcome to gTTalk. The hitch in your photo uses an electric actuator to lift. That may be a reasonable choice for you as it is much easier to implement than tapping into the hydraulics and adding control valves if that is even possible. You may want to do a bit more research into the limitations of the transmission and what that means for your plans to use ground engaging attachments.
#12 superaben OFFLINE
superaben
    Con Man
  • 7,665 Thanks
  • 5,677 posts
Posted March 26, 2013 - 07:57 AM
Welcome to GTTalk!
I agree with those who said put a hydraulic pump on the PTO.  Garden hydrostatic pump/drive systems aren't really equipped with a large enough reservoir to handle other uses.  However, I may be wrong.
Ben W.
#13 8tyman8 OFFLINE
8tyman8
  • 414 Thanks
  • 731 posts
Posted March 26, 2013 - 12:09 PM
http://www.ebay.com/...=item2c6b5b0f0c
Also there is a spot to mount a hydraulic pump to the engine ....
#14 OldBuzzard OFFLINE
OldBuzzard
  • 6,609 Thanks
  • 4,659 posts
Posted March 26, 2013 - 01:30 PM
I did a bit of Google searching, and it appears that the G4200  did have a CAT 0 3-pt as an option.
#15 8tyman8 OFFLINE
8tyman8
  • 414 Thanks
  • 731 posts
Posted March 26, 2013 - 04:46 PM
http://www.ebay.com/...=item2c6d91076c
i think this is the Hydro ... ?
Also tagged with one or more of these keywords: hydrostatic drive, hydraulics, custom hydraulics, modified hydraulics
