Porter Cable Surburban Restoration Begins Today
39 replies to this topic
#31 michelle OFFLINE
michelle
    Tractorholic by Marriage
  • 331 Thanks
  • 303 posts
Posted November 27, 2013 - 08:09 PM
Assembly begins tonight.
1479355_10101734525026938_677976219_n.jp
Howie is helping Adam.
1425531_10101734524996998_175613470_n.jp
  • wilberj, MH81, sacsr and 1 other said thanks
#32 jabelman OFFLINE
jabelman
  • 2,163 Thanks
  • 1,559 posts
Posted November 27, 2013 - 08:40 PM
Looks good adam. If you need any info or photos let me know. I just got my second one tore down for the winter among other projects
#33 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted November 28, 2013 - 07:54 AM
jabelman, What did you do for decals?
#34 jabelman OFFLINE
jabelman
  • 2,163 Thanks
  • 1,559 posts
Posted November 29, 2013 - 01:19 PM
I have them drawn in autocadd but i havent printed them out yet. All is going to be black. I attached a photo of the red ones hood sticker for ref. I found an old 50's sale brochure that i am going to follow that design which was slightly different. Also i saw one for sale in original paint (interesting that is the next serial# up from the red one) it had the same hood decal but the side hood script was all red and no decals on the floor sides (mark 1 in a box). There is shift pattern decal too.
Also watch your motor mounts brackets. The one i got from you was welded and my red one was welded in the same spot. The engine really bounces around i put bigger bushings in the first one which helped. Let me know i will have the guy print another set if you want when i get them.
#35 jabelman OFFLINE
jabelman
  • 2,163 Thanks
  • 1,559 posts
Posted November 29, 2013 - 01:24 PM
Heres the photo
#36 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted November 29, 2013 - 05:29 PM
Looking forward to seeing the decals on your restoration.
I'd like to know more about the issues with the motor mount brackets.  I have a couple 6hp moto-mowers that are roughly the same and would like to know if there's something I should be looking out for.
#37 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted November 29, 2013 - 07:52 PM
I plan on using solid metal bushings and not rubber to keep the engine from bouncing around. A little vibration is ok with me.
#38 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted November 29, 2013 - 07:53 PM
Jableman, you didn't have the decal printed on a chrome back round?
Edited by bread320i, November 29, 2013 - 07:55 PM.
#39 jabelman OFFLINE
jabelman
  • 2,163 Thanks
  • 1,559 posts
Posted November 29, 2013 - 10:18 PM
No i was going to do it separate. You can get adhesive foil that works thats pretty decent. I tried looking for the original style ribbed foil but no luck i am sure its available somewhere?. Did you keep the throttle on the hood? That area had the same chrome on it too. I filled that in and painted it white and moved it on to the side panel. What shade of green did you use? I went with emerald. Still deciding how to do the other one. Might go with the moto mower metallic blue instead of green just keep them different.
#40 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted November 30, 2013 - 07:54 AM
My throttle was already on the frame cover. I have not decided what I am doing with the rear of the hood, but I guess I should figure it out soon.
