I Have The Cub 124 In The Garage Now!
24 replies to this topic
#16 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted March 28, 2013 - 09:09 PM
It could be the condensor. I have oftentimes tried everything else and then that turned out to be the problem.
#17 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted March 28, 2013 - 09:10 PM
it might not sure on that one. hopefully someone else will chime in on that
#18 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted March 28, 2013 - 09:14 PM
That is new too :D
  • LTD said thank you
#19 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted March 28, 2013 - 09:19 PM
That is new too :D
Oh well, there goes that theory :( . Could it have a sticking valve? Hows the compression?
#20 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted March 28, 2013 - 09:23 PM
Compression is 50 psi.
#21 IHCubGuy OFFLINE
IHCubGuy
  • 1,611 Thanks
  • 1,638 posts
Posted March 28, 2013 - 09:33 PM
You say that you got a consistent spark today.  Was it a good blue spark or a more weak yellow spark?  If its not a nice hot blue spark then something in line is not right.  Plug, points burned a little, plug wire, coil, condensor.  When I am working on a small engine and I dont have starter fluid on hand and I know that the carb may have an issue I take the plug out and dump a little gas in the plug hole and then put it back in and give it a crank.  If the spark is there it should fire off if it has good compression.  At the least make a put or two before it burns the gas out of the cylinder.
#22 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted March 28, 2013 - 09:35 PM
It had a good healthy blue spark! Tomorrow I will try a little gas; I normally use gas, but somebody gave me the can of starting fluid one time.
#23 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted March 28, 2013 - 09:37 PM
Are you getting good spark at the points?
#24 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted March 28, 2013 - 09:41 PM
I did not check, I will look at them tomorrow.
#25 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted April 11, 2013 - 01:57 PM
It took much longer then I wanted, but I got a spark plug. I put it in and it now only runs on spurts of gas. I knew the carb would need to be cleaned, and when I took it off... it was horrible! I now have it in carb cleaner.
