Wanted
Mtd Lawn Tractor Wiring Harness
wiring mtd mower
2 replies to this topic
#1 98Murray OFFLINE
98Murray
  • 50 Thanks
  • 36 posts
Posted March 24, 2013 - 11:25 PM
I am working on a mower for a friend and need a new wiring harness because the old one is chewed up and no good and I replaced the old motor with another. The old engine was a Tecumpseh 15HP OHV. Replacement engine is a Briggs & Strtton 11HP flathead. the wiring harness has 4 safety switches
seat
reverse
PTO
Brake
And the motor has a total of 4 wires, starter, coil kill, and 2 stator wires. The headlights go to the ignition switch so when its running the headlights are on. It has a 5 pole ignition switch and 3 pole sylinoid. also has NO ammeter. If anyone has a wiring harness like the one I am needing or very similar and are willing to sell for a reasonable price please let me know. I also need the PTO safety switch if you have one. Heres some photos of the tractor.
#2 glgrumpy OFFLINE
  • 8,549 Thanks
  • 7,877 posts
Posted March 25, 2013 - 06:59 AM
You will need a wiring diagram, usually in the manual for your tractor. Can get them from MTD site if you have model and series numbers. OR, check on here in manuals section, they have quite a bit. Then I would go one wire at a time and run them the way diagram shows and compare to your old harness for lengths and where to run it. You may find you can use some of old harness wires and rebundle them into a new harness. It is a slow and painful process. You might check with MTD and see if one is available for yours if it is not too old of model.
#3 Guest_Fluid_*
Guest_Fluid_*
  • Guests
Posted December 31, 2013 - 10:39 PM
seat
reverse
PTO
Brake
Did you ever find a harness for the yard machine?
Also tagged with one or more of these keywords: wanted, wiring, mtd, mower
