Cut Away Engines
15 replies to this topic
#1 Ryan313 OFFLINE
  • 3,242 Thanks
  • 5,159 posts
Posted March 24, 2013 - 05:16 PM
The other day I was in the metal shop at school (not the welding shop at Boces) and I saw a couple of cut away engines. I have never seen one in person before and, I didn't know how cool they where to look at! I was playing with one for about 5 minutes, and then my friend needed something so I had to stop.
I have 4-5 K series kohlers, and I was thinking about doing it to one of the rougher ones.
How hard are they to make? Has anybody here made one? Pictures? And what would I use to cut it apart?
  • larryd and JRJ have said thanks
#2 8tyman8 OFFLINE
8tyman8
  • 414 Thanks
  • 731 posts
Posted March 24, 2013 - 05:34 PM
I know alot of cutaways are done with the band saw but i think the same could be done wit a sawzall ...  the only ones i have seen was model 8-9 briggs (aluminum) i want to make one from a model 19 as they are plentiful and the bores are aluminum so it would be easy to cut ...
  • Ryan313 and larryd have said thanks
#3 glgrumpy ONLINE
  • 7,712 Thanks
  • 7,323 posts
Posted March 24, 2013 - 05:39 PM
Willing to bet a big metal cutting disc is used in a stationary machine to make those up. Would think any hand held one would be all over the place and make crooked cuts. Heck, I bet when done cutting they even mill the cut surfaces to make prettier and sanding, and polishing, and painting all the pieces inside and out! Sure is neat on big engines, not so sure worth the bother for little rig.
#4 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,034 Thanks
  • 1,457 posts
Posted March 24, 2013 - 05:44 PM
I have never seen one in person,just pictures of them. Sounds like a cool idea.
#5 Ryan313 OFFLINE
  • 3,242 Thanks
  • 5,159 posts
Posted March 24, 2013 - 05:47 PM
I wonder if I would be able to use a grinder, then clean and straighten the cuts with a mill?
I just went out to look at what engines I had; it is between these two K181 engines, they are both pretty rough, especially the one on the right. I don't foresee needing them for anything, and they would both take quite a bit of work to get running.
644EEE2E-2114-4B5D-B1DB-E7E90DEF226B-564
Edited by Ryan313, March 26, 2013 - 02:20 PM.
  • larryd said thank you
#6 MF10Ryan OFFLINE
MF10Ryan
  • 244 Thanks
  • 74 posts
Posted March 24, 2013 - 06:33 PM
I was thinking about doing this with an old push mower engine.  At least for a first attempt in case i trash it, then I haven't junked a good horizontal for nothin'
  • Ryan313, backwoods and larryd have said thanks
#7 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted March 24, 2013 - 07:05 PM
There used to be a plastic model of a chevrolet engine cut out like that for one to assemble. I had thought at time about getting one but never did. Now this was years ago and I don't know if they are still made. You would have to go to a model store or toy type store. Just my 2 cents worth.
Dick
  • MF10Ryan and larryd have said thanks
#8 Ryan313 OFFLINE
  • 3,242 Thanks
  • 5,159 posts
Posted March 24, 2013 - 07:14 PM
Dick
I know what you are talking about! About 5 years ago my cousin (year older then I am) got one for Christmas, and I helped put it together. When we were putting it together, we could not find the Wrist pins, so we cut our own! You know how all the plastic pieces come in one piece, and you have to pop them apart? We used the remnants of the holder for the pins. Worked great! Also, after we were done we found the wrist pins. Lol!
#9 LilysDad OFFLINE
LilysDad
    --Crazy about GTTalk-- 'sort of'
  • 11,400 Thanks
  • 8,663 posts
Posted March 24, 2013 - 07:24 PM
How well do you think these engines will run after they are cut up???
What?!!! I'm just asking. I saw a Chevy 4 cyl. at a flea market running without an oil pan.
#10 UncleWillie OFFLINE
  • 14,205 Thanks
  • 8,180 posts
Posted March 24, 2013 - 07:34 PM
The technical term for that is sprue.
#11 wilberj OFFLINE
wilberj
  • 4,632 Thanks
  • 5,422 posts
Posted March 24, 2013 - 07:39 PM
So your telling me it will never burn oil? :D
#12 backwoods OFFLINE
backwoods
  • 2,574 Thanks
  • 2,790 posts
Posted March 24, 2013 - 07:42 PM
in the tech room at school there is a cut away of a neon motor and a rear axle im guessin a chevy so that students can see how the internals function
#13 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,179 Thanks
  • 5,775 posts
Posted March 24, 2013 - 07:51 PM
It's a Chevy, it'll find a way to burn oil.
  • LilysDad and larryd have said thanks
#14 UncleWillie OFFLINE
  • 14,205 Thanks
  • 8,180 posts
Posted March 24, 2013 - 07:59 PM
Chevys run on hope and dreams.
  • 8tyman8 and larryd have said thanks
#15 LilysDad OFFLINE
LilysDad
  • 11,400 Thanks
  • 8,663 posts
Posted March 24, 2013 - 08:02 PM
Only if you use the proper after market oil additives.
