Cleaning (underneath) Decks?
21 replies to this topic
#16 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted March 26, 2013 - 07:50 PM
If you want to try something different, paint the underside of your deck as usual, wait a day or two to dry, and then coat the entire underside with two-three coats of polyeuthane. After the poly is dry, apply two or three coats of car wax. Try this for one season, and see if it makes a difference.
As for washing your decks out each time you mow, make sure you run the deck for at least five minutes when you're done, so that you dry out the bearings and belts. If you don't, the water lays in the bearings and will rust, and wet belts will eventually dryrot and get brittle with humidity. If you have a blower, blow off the worst of the grass first before soaking the deck with water. Water spray will get most of the grass off, but it will also trap the grass.
  • larrybl said thank you
#17 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,010 Thanks
  • 4,418 posts
Posted March 26, 2013 - 09:26 PM
Thanks for the tip. Other than the paint the rest is out of budget. The problem I have is even after one mowing I get this hard almost baked on grass resedual (named by my Grandson "lawn mower poop"). The wire wheel removes most it and the paint, The preshure washer removes it and leaves the paint intact, but is labor entensive. (deck removal).  BMP mandrals are grease fittings and are greased after each mow. RED's are sealed and I am reluctent to use the power washer on it. I don't let water lay on top of the deck, After blow-off and washing they sit in the sun and wind till dry. I do need to go under the deck more often (during the mowing season) to remove the big buildup) Been looking at a MowJack at T/S for this, but I think BMP is too heavy. May work good for RED but now I would need to find shop space for it.
#18 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,010 Thanks
  • 4,418 posts
Posted March 29, 2013 - 04:15 PM
Almost done with BMP's deck cleaning, very labor entensive but I have help. All that's left is to install the blades and shields and find a place to store this monster as I have more use of the BMP without the deck right now. He is towing the trailer around.
#19 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted March 29, 2013 - 04:36 PM
Bottom line, if you want any deck to look new.
1.Clean/wash it with soap and water
2.Sand it and wipe down with metal wash
3. Prime it
4. Paint it 2 -3 coats
5. Looks like brand new, next step is most important
6. Never use it again :D
No matter what is used it won't last, even bed liner stuff will come off from the abrasive of only the grass, never mind ,sand,rocks, wood, leaves, etc. :thumbs:
#20 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,010 Thanks
  • 4,418 posts
Posted March 29, 2013 - 08:02 PM
3. Prime it
Not so much to look "New" but to store without rusting till RED breaks down, or worse. Then All I have to do is install the deck, not worry about blades, rust, mandrels, or grease. Install n go. It may be this seasion, 2 years, 5??? Dont know. But the deck will be used again.
Found a storage place, Needed to move the Pearless 6 speed Hi/Lo. But I needed to start on that rebuild any how.
#21 gtcsreg OFFLINE
gtcsreg
  • 2,017 Thanks
  • 1,979 posts
Posted March 29, 2013 - 09:49 PM
I need to clarify that the hose hookup on my JD only puts water below the deck.  The belts are never wet.  As for the bearings I don't think so but can't say I'm sure on that.  I think I was told the part was around $10 bucks two or three years back.
#22 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,010 Thanks
  • 4,418 posts
Posted March 29, 2013 - 10:02 PM
When I greased the mandrils they took almost 2/3 of a large cartrage. Not sure what it would cost to replace the 30+ year old bearings.
I'll keep them well greased.
