Dump Find. Tec H70 W/ Onan Generator.
30 replies to this topic
#16 DH1 ONLINE
DH1
    Electric Tractors
  • 5,366 Thanks
  • 5,605 posts
Posted March 24, 2013 - 05:03 PM
I've seen these for sale at Princess Auto. Belt driven generator head.
http://www.brandnewe...s.com/ab50.aspx
#17 glgrumpy OFFLINE
  • 8,741 Thanks
  • 7,978 posts
Posted March 24, 2013 - 05:35 PM
Make mount bracket for front of tractor, but leave gen engine on it and run it when used. OR, a little trailer for the back? Then put a hitch on that little trailer to put on the next implement you wish to tow to site and use. I'ld leave it alone and use as designed myself.
#18 Ryan313 ONLINE
  • 3,404 Thanks
  • 5,241 posts
Posted March 24, 2013 - 08:25 PM
I like GL's idea of a small trailer!
I read that generators run in reverse will open a black hole...
#19 IamSherwood OFFLINE
  • 8,395 Thanks
Posted March 28, 2013 - 06:10 AM
After doing somemore research, and head scratching, I decided to
go ahead with this project.
This is what I've accomplished so far.
My brother will be making up the stub shaft with taper today.
I have correct size pulley. The electrical panel, I will change
and mount ontop of the gen.
Being the engine PTO pulley is 4" dia. and the gen pulley is 2.75", there
wasn't any room to use an idler pulley to act as a clutch/tensioner.
So, I hinged the gen mounting plate, so it could be the tensioner.
I'm looing for ideas, on what I can do there, so engagement/disengagement
can be quicker, than pulling out wrenches.
I decided to not keep this gen/motor as it was, as I already have several
newer stand alone generators, and I didn't want another Techumseh
to maintain.
Edited by IamSherwood, March 28, 2013 - 06:14 AM.
#20 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted March 28, 2013 - 06:32 AM
Once you have it set up for the belt, could you figure out how to use this type latch to hold in place?
  • IamSherwood said thank you
#21 IamSherwood OFFLINE
  • 8,395 Thanks
Posted March 28, 2013 - 06:44 AM
Yes Kenny!!!! A flat bar standing up between the adjustment bolts. Holes in that flatbar.
And that springy thingy on the gen base. I might even have one of those.
#22 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted March 28, 2013 - 06:55 AM
I'm not sure on your pivot point for the generator. If that gives enough shorter distance for the belt to be put on easily, then the weight of the generator should put tension on the belt. Then a bit more hand pressure to lock it in place. Just have to make sure you don't have too much tension on the belt and shaft going into the generator. Just an idea to look into. That latch is something I found Googling boat trailer tie down latch. I was looking for the type of latch that has the chain that hooks to the back of a boat to hold it on the trailer. That would make it a bit more adjustable.
#23 IamSherwood OFFLINE
  • 8,395 Thanks
Posted March 28, 2013 - 07:08 AM
That latch could be just to hold the gen up, when disengaged.
Gravity should work to engage, and the nuts, adjusted so as not
to apply too much pressure on the shaft. If gravity doesn't work
I have a some of those black rubber bungies with a closed loop
on the one end. They're used as battery hold downs.
Did you find those straps?
Edited by IamSherwood, March 28, 2013 - 07:14 AM.
#24 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted March 28, 2013 - 07:11 AM
The ones I am thinking about were used on older trailers at the back. Everything now is using nylon straps instead of the chain. I have some small ones out back, just no pics handy of them.
EDIT: I went out and got one. Took a pic for you.
  • IamSherwood and Moosetales have said thanks
#25 IamSherwood OFFLINE
  • 8,395 Thanks
Posted April 01, 2013 - 08:33 AM
I've never seen those before. You could probably make those up, using those mini chain binders. Those
springs where used on the old cable steering systems in boats, 40 years ago.
#26 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted April 01, 2013 - 08:42 AM
Yep! Old School stuff.
#27 IamSherwood OFFLINE
  • 8,395 Thanks
Posted April 01, 2013 - 08:48 AM
I got this thing assembled, and sort of tested yesterday. The belt I had was a bit to
long, so it slipped, and the gen never got to full RPM. But it did make power.
It was a real trick to get it assembled, and shimmed, so as not to put any
side load on the taper shaft.
I took apart, and used several feeler gauges, and shimmed around the armature, to
get it centered in there, and then had to get the shims out of those oval holes in the casing
after everything was tightened up.
  • Newpaws493 said thank you
#28 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted April 01, 2013 - 04:31 PM
Ever thought about using 2 bearings with the pulley in between?
#29 maggiewaggie OFFLINE
maggiewaggie
  • 34 Thanks
  • 36 posts
Posted April 21, 2013 - 07:09 PM
Thought for a minute that you had my generator. My husband took the generator out of our RV to rebuild it, then he passed away. The generator was taken by some "scrappers" who came to get some old cars. By the time I missed it, it was long gone. I'm more vigilant now, but I couldn't have reinstalled it anyway. Good luck with yours, beware the "scrappers." Mine was a generac.
  • tractorgarden and boyscout862 have said thanks
#30 olcowhand ONLINE
  • 42,399 Thanks
  • 31,803 posts
Posted April 21, 2013 - 07:50 PM
Somehow missed this thread Will.  Where are you with this project now?
