Briggs & Stratton Magnetron Interchangeability
12 replies to this topic
#1 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted March 22, 2013 - 03:03 PM
  Is it possible to interchange a points style magnetron to one without points? The reason I ask is; I have an Allis Chalmers Big Ten with a points style Magnetron that is bad and I have a no-points style off a later B&S that I would like to put on? Is it possible or will it screw up the timing?
#2 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted March 22, 2013 - 03:34 PM
I think you are talking about the coils them selves? If so they won't interchange. I am going to go out to the shop to check something, as I have 1 magnetron 8hp and 1 points style. I'll see what the differences are.
  • LTD said thank you
#3 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted March 22, 2013 - 03:43 PM
Maybe I'm wrong? I just looked and the 2 flywheels look the same. If that were the case then It looks like all that you would have to do is swap the coils? Maybe someone else will know for sure. In the mean time I'll try to find out.
#4 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted March 22, 2013 - 03:58 PM
From what I see so far, The polarity of the magnets on the flywheels are reversed. So you would either have to swap flywheels or ship the flywheel to Briggs and they will reverse polarity for free, you just cover shipping. The other thing is you would have to put a plug in the hole where the points plunger is so it doesn't leak oil. unless you could just leave the points in and just leave the wires off??
It will be interesting if someone else chimes in that maybe has done this already.
#5 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted March 22, 2013 - 05:10 PM
I thought the coil and magnetron were the same thing?
#6 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted March 22, 2013 - 05:15 PM
Thanks for the fast input,Chris. I tried to do it once and it ran,but it ran terrible. I couldn't get any revs out of it and it would skip badly. I thought it was a different problem at the time though.
#7 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
The one for the Magnetron (no points) is different, it has a built in transistor in it. it looks similar but it is not.
#8 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted March 22, 2013 - 05:16 PM
Do you have a flywheel that you could swap?
#9 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Ok, I see now. Thanks for clearing that up for a dummy. :wallbanging:
#10 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted March 22, 2013 - 05:17 PM
I don't have one, no.
#11 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted March 22, 2013 - 05:19 PM
Your not a Dummy lol. This is how we all learn things. And it is great that you asked the question! I didn't know the answer to this and had to do a little research, So... in reality you helped me learn something new today also :thumbs: So Thank you! :D
#12 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted March 22, 2013 - 05:56 PM
I just did a little research also and found this video.
  • chris m said thank you
#13 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted March 22, 2013 - 07:41 PM
A couple things. I don't understand why he left the points plunger in the hole? It could pop out then you will be leaking oil everywhere!. And he didn't mention anything about the magnets on the two types being different polarity?
Like I said hopefully someone who has done this comes along and tells us for sure. If not I will have to do some experimenting on my engines soon.
