Doh!
10 replies to this topic
#1 TAHOE ONLINE
TAHOE
  • 8,186 Thanks
  • 5,765 posts
Posted March 22, 2013 - 09:53 AM
That moment after you've already pulled carb off and begin to take apart for cleaning and realise you already used that new can of carb cleaner you just bought and are now out
:wallbanging:  :wallbanging:  :wallbanging:  :mad2:  :mad2:
  • Alc, tinbender7, HDWildBill and 4 others have said thanks
#2 Cat385B ONLINE
    HAZMAT CAT
  • 14,287 Thanks
  • 10,116 posts
Posted March 22, 2013 - 10:02 AM
Is that similar to breaking out the paint gun after a long period only to open the can of paint and find out all the paint dried up and is worthless?
  • Alc, tinbender7 and HDWildBill have said thanks
#3 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted March 22, 2013 - 10:06 AM
Yes I think you got the idea,  DOH!! it happens to the best of us.
Dick
  • tinbender7 said thank you
#4 tinbender7 OFFLINE
tinbender7
  • 1,115 Thanks
  • 784 posts
Posted March 22, 2013 - 10:34 AM
or get out the paint gun and realize you forgot to clean it the last time you used it.
Edited by tinbender7, March 22, 2013 - 10:34 AM.
#5 NJKen OFFLINE
NJKen
  • 1,361 Thanks
  • 1,284 posts
Posted March 22, 2013 - 11:42 AM
Bob, buy more then one at a time !! : )
Advanced Auto just had them on sale a few weeks ago, I bought 6 @ $3.00 each. Used 2 up already.
#6 TAHOE ONLINE
TAHOE
  • 8,186 Thanks
  • 5,765 posts
Posted March 22, 2013 - 11:53 AM
I had bought a new can few weeks back for this particular carb cleaning, but end up using it on some caked on grease on my OH160 I was cleaning/prepping for paint. I remembered that when I starting tearing carb apart. :hitting_self_roller:
Been there with the paint cans too, not to forget the partially used tube of caulk or the half tube of RTV for gaskets that was dried up when I needed it . You would think I would learn by now  :D
#7 Marty'70 ONLINE
Marty'70
    I didn't do it! Unless you have paperwork to back it up
  • 866 Thanks
  • 721 posts
Posted March 22, 2013 - 12:08 PM
Call me a bad salesman, but i usually ask if someone is buying a tube ov silicone for one jub or if they will be using alot of it. I suggest the smaller tube just for the fact that the next time they go to use it and it's dried up they won't be as pissed if they wasted $3 instead of $10
#8 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted March 22, 2013 - 01:27 PM
Worse yet:  when you say to a your neighbor "I've got exactly the stuff you need to get that carburetor cleaned out,  right over....here..."
Then you sing with Willie, "On the Road Again!"
Ben W.
#9 HDWildBill OFFLINE
  • 8,978 Thanks
Posted March 22, 2013 - 03:49 PM
I don't know how many times I have reached on a self to get something and woop's it is either toast or not enough left.  That's when I whip out the old trusty phone and call the wife to go pick what ever I need up for me.  :smilewink:   Usually in 15 -20 min's she is pulling in the drive drops it off and away she goes again doing what ever she is doing.
#10 olcowhand ONLINE
  • 42,498 Thanks
  • 31,835 posts
Posted March 22, 2013 - 06:52 PM
Oh, that is bad....VERY bad!  Quite similar to using hardener, then leaving the mix in the gun just a little too long!
#11 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted March 22, 2013 - 08:29 PM
how about when your spraying Teflon lube thats in a black can in a semi auto pistol that keeps jamming and you set the can down next to a can of 3m adhesive spray that is also a black can . do i need to tell you what happened next ?  :booboo:
  • MH81 and IamSherwood have said thanks
