Headlight Fuse
9 replies to this topic
#1 Rock farmer ONLINE
Rock farmer
  • 1,298 Thanks
  • 1,274 posts
Posted March 21, 2013 - 07:13 PM
When I got my LGT 165 the lights did not work. I found the inline fuse holder which contained a blown 7.5 amp short buss fuse. I replaced it with a 9 amp fuse. That worked for a while. then blew. It seems to me it should use a twenty amp fuse?
The service manual only shows a fuse. It gives no value. I'm using a 15 amp now.
What should be there?
Thanks,
Joe
#2 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted March 21, 2013 - 07:19 PM
Not sure about your Ford, but all of my John Deere's use 9 amp fuses. Not sure why your headlights are needing more than 9 amps. Something doesn't seem right there.
#3 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted March 21, 2013 - 07:21 PM
Are you sure that fuse is for the headlights only or is it a main fuse for the entire charging circuit. If it's the main fuse then it should be at least 15amps as that's what the generator coils would typically be in those Kohler K341 engines.
#4 Rock farmer ONLINE
Rock farmer
  • 1,298 Thanks
  • 1,274 posts
Posted March 21, 2013 - 07:50 PM
It's between the ignition key switch and the light switch. So it only protects the two headlight and the two tail lights. Was 7.5, Napa didn't have any 7.5 so I used a 9 amp. It snowed on the machine and the fuse blew. When I replaced it with the 15 amp, I found one headlight out. I replaced that, and all work.
Joe
#5 KennyP ONLINE
  • 40,888 Thanks
  • 47,094 posts
Posted March 22, 2013 - 05:33 AM
There should be two fuses, one for lights & one for the charging circuit. If you are blowing fuses still, you may have a bad wire (insulation worn through?) somewhere. Doesn't take much to blow a fuse. I have no idea on the values of the fuses.
  • Rock farmer said thank you
#6 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted March 22, 2013 - 06:23 AM
Kenny, is that info in the service manual? It seems like 9amps would be enough. With vibration, heat and the high inrush current when the lights are first turned on the fuse may have to be over rated in order to last. A burned out bulb can alos fail in a way that causes it to draw extra current before it pops.
#7 KennyP ONLINE
  • 40,888 Thanks
  • 47,094 posts
Posted March 22, 2013 - 07:06 AM
 Yes. It shows 2 fuses in the wiring diagram. Nothing stated on fuse sizes, though, that I have found.
#8 KennyP ONLINE
  • 40,888 Thanks
  • 47,094 posts
Posted March 22, 2013 - 07:25 AM
I checked New Holland and the regulator fuse should be a 30 amp. Nothing on the lights fuse.
#9 Rock farmer ONLINE
Rock farmer
  • 1,298 Thanks
  • 1,274 posts
Posted March 22, 2013 - 07:30 AM
I read the owners and service manuals. The only identify that fuses are there. No info on type or rating.
Joe
#10 KennyP ONLINE
  • 40,888 Thanks
  • 47,094 posts
Posted March 22, 2013 - 07:42 AM
Joe
That's what I found, Joe.
