Can Someone Explain The [engine] Set Up Here.
17 replies to this topic
#1 Gfann OFFLINE
Gfann
  • 194 Thanks
  • 228 posts
Posted March 19, 2013 - 04:40 PM
I found these pictures on the internet. I spend time on occasion just looking at different machines I find on the internet and learning something new or discover now concepts in build and design. I am a newb to engine stuff I got into tractors about two or so years ago and every sense then I've absorbing whatever info I can. This particular image of someones awesome build of a radio flyer roadster, I call it. It shows an engine with what appears to be four exhaust pipes I guess, coming off the crankcase I see a exhaust line running under the cart but I was wondering what this setup does performance wise for the engine? Could bug someone for a little insight on this little project.
  • hamman, Newpaws493 and larryd have said thanks
#2 farmerall OFFLINE
farmerall
  • 2,204 Thanks
  • 1,474 posts
Posted March 19, 2013 - 04:50 PM
The things on top of the engine are just for looks. They were common on older hot rods with the performance intakes that have aton of single barrel carbs. I can't remember what they are called though. I managed to find a picture on google to give you an idea of what they are normally used for. That is a sweet hot rod wagon too.
  • larryd said thank you
#3 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,464 Thanks
  • 5,768 posts
Posted March 19, 2013 - 04:51 PM
The gas tank in the front scares me!  If he hit something it could cost you your sight or worse!  The pipes are ornamental and it sure does look cool!  The engine & drive system is much like the ones they use on go cart racing tracks all over but those are designed with the engines (& gas tanks) on the back of the cart..  It's pretty neat looking for a show piece..
#4 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted March 19, 2013 - 04:52 PM
That engine Appears to be a honda Gx340 or a Gx390.. the Exhaust "Thing" is mounted on the fuel tank mounts/tabs on the block they appear to do nothing just part of the Theme ... the only benefit (if they are aluminum) would be that it would conduct some heat from the block...and radiate it into the air...
But its quite need contraption .
#5 Marty'70 ONLINE
Marty'70
    I didn't do it! Unless you have paperwork to back it up
  • 862 Thanks
  • 719 posts
Posted March 19, 2013 - 04:53 PM
that thing is awesome! it would be cool to have and cruise around the shows on. it appears the four exhaust stacks are the owners attempt to look like old school fuelie velocity stacks. looks cool though.
#6 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted March 19, 2013 - 05:06 PM
I doubt if anything on the setup that you were asking about is function: I think it is all the "cool" factor.
All it needs to be really fun is a Clinton engine like the classics, not a modern Honda.
Ben W.
#7 EconChuck OFFLINE
EconChuck
  • 252 Thanks
  • 289 posts
Posted March 19, 2013 - 05:17 PM
Hi,
That setup is to simulate individual or "stack" injectors. Other than Nostalgia cars, the sprint cars of today use stack injectoin systems. Each individual stack feed one cylinder of an engine, had a throttle plate, and at least one jet/nozzle that feed gasoline/alcohol to that cylinder.
In this case it is only for looks.
Chuck
  • tractorgarden, Gfann, larryd and 1 other said thanks
#8 Gfann OFFLINE
Gfann
  • 194 Thanks
  • 228 posts
Posted March 19, 2013 - 05:24 PM
All vary useful info. I noticed there is a line running in-between the stacks to some sort of mechanism. Any ideas? Is it some sort of a fuel pump?
#9 farmerall OFFLINE
farmerall
  • 2,204 Thanks
  • 1,474 posts
Posted March 19, 2013 - 05:40 PM
it looks like there is a vaccum fuel pupm tucked inbetween those stacks.
#10 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted March 19, 2013 - 05:44 PM
Very nice
larryd
#11 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted March 19, 2013 - 05:53 PM
untitled col.png Cool and kind of old school!
#12 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted March 19, 2013 - 05:55 PM
They are called "Velocity Stacks", designed to speed up the air going into the motor. They were in the. 60's when you had a row of 2 barrel Webbers or Stomberg carbs, some of your early injection system used them.
I agree on this motor they for show, as we're most of them.
#13 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,464 Thanks
  • 5,768 posts
Posted March 19, 2013 - 06:01 PM
A buddy of mine had one of those intakes and was going to install it on one of his cars but ended up just selling it..  They are a PITA to set up..  But once you got them right they rocked!!
#14 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted March 19, 2013 - 06:14 PM
My guess would be a Honda or Honda clone engine, 6.5hp or so
with a Comet "Tork a Verter" setup on it,
http://www.mfgsupply...qtav30kits.html
that drives a small riding mower differential through a chain.
Edited by DH1, March 19, 2013 - 06:24 PM.
#15 Enginerod OFFLINE
Enginerod
  • 234 Thanks
  • 289 posts
Posted March 19, 2013 - 06:31 PM
The stacks are a fake Hilborn fuel injection setup, the thing in the middle between the stacks is a fake barrel valve, the barrel valve controlled the amount of fuel relative to throttle position. My dad ran a Hilborn on a 32 Ford in the late 60's early 70's, the injection setup is on a shelf im my garage.
  • Chopperhed said thank you
