Brinly 3pt Plow Questions
6 replies to this topic
#1 farmerall OFFLINE
farmerall
  • 2,217 Thanks
  • 1,482 posts
Posted March 19, 2013 - 12:24 PM
I originally bought this plow becuase the price was really good and so I could possibly trade it for a sleeve hitch plow that because I don't have a tractor with a 3pt. I am working on getting a sleeve hitch plow so I don't need this one now. It's a 12in plow but I need help to find out if it is cat0 or cat1 plow. I was told that brinly never made this plow in a cat1 setup. The pins are larger that 5/8 so they won't fit in a cato but the toplink hole is 5/8 so I'm thinking it's a cat0 that some one changed the pins on. Can anyone help determine for sure what hitch size this plow is so I can know for when I sell it.
#2 CoryG OFFLINE
CoryG
  • 45 Thanks
  • 29 posts
Posted March 19, 2013 - 01:24 PM
That looks like a Cat-0 plow with Cat-1 pins, just like you assumed. That 3-point frame should measure about 20" side-to-side. Cat-1 spec is 26". I bought a Brinly 12" plow a while back just like that which also had Cat-1 pins.
  • farmerall said thank you
#3 OldBuzzard OFFLINE
OldBuzzard
  • 7,108 Thanks
  • 4,821 posts
Posted March 19, 2013 - 01:27 PM
Most likely a PO was using it on a newer sub compact that had a CAT 1 hitch.
Not a problem, as it will be easy enough to change :D :D :D
#4 Kurtee OFFLINE
Kurtee
  • 594 Thanks
  • 473 posts
Posted March 19, 2013 - 02:32 PM
The front mast is on backwards is the only problem I see with this plow.
  • OldBuzzard and farmerall have said thanks
#5 Littledeere OFFLINE
Littledeere
  • 1,664 Thanks
  • 1,490 posts
Posted March 19, 2013 - 03:02 PM
Brinly did make that style plow in a cat1 pin size with standard cat 1 mast it was a PP 1235
it's to hard to tell in the pic with that is what this is or if someone just anded big pins
And Kurtee is correct the mast is turned around
Edited by Littledeere, March 19, 2013 - 03:12 PM.
#6 OldBuzzard OFFLINE
OldBuzzard
  • 7,108 Thanks
  • 4,821 posts
Posted March 19, 2013 - 03:05 PM
I didn't notice that.  Nice catch :thumbs:
Oh well, just another easy fix.
I'm positive that the next owner <cough, cough> won't have a problem doing that :D :D :D :D
Edited by OldBuzzard, March 19, 2013 - 03:07 PM.
#7 farmerall OFFLINE
farmerall
  • 2,217 Thanks
  • 1,482 posts
Posted March 19, 2013 - 03:06 PM
I think the previous owner may have used it with his small Kubota tractor before. Thanks for all the help.
