Going To Build A 3ph For My 1650
39 replies to this topic
#16 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted March 26, 2013 - 04:16 PM
Nothing special but some before, during(got side tracked) and after for the brackets. One set goes on the axle and the other set goes under the seat pan. Hopefully I can get them on the tractor tonight.
Sent from my HTC One VX using Tapatalk 2
#17 twostep OFFLINE
twostep
    Rockstar
  • 1,985 Thanks
  • 2,536 posts
Posted March 27, 2013 - 09:33 AM
If I leave the arms the length they are this is how far they will stick out behind the tractor. Seems a little far. I've decide to build a sub frame that comes from the axle up the back of the tractor to the top of the seat pan. I think that will be the easiest way to mount everything with out disturbing to much of the tractor.
I don't think that emu is too sure about what's going on here...
#18 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted March 30, 2013 - 07:50 PM
Getting the holes drilled and the mounting bracket fitted. I'm against the clock with the weather. Need this done by the weekend. The right bolts on the axle are longer than the left.
  • bgkid2966 and twostep have said thanks
#19 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted March 30, 2013 - 09:07 PM
This is where I'm ending the night. Does the lift rod connect to the bracket on the right of the dash tower?
#20 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted March 30, 2013 - 09:12 PM
Looking good so far! Keep up the good work!
Geno
  • BairleaFarm said thank you
#21 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted March 30, 2013 - 09:16 PM
I haven't welded in a couple years so hopefully they hold. Something happened during fab and I'm 1/16 if a inch off on the top link mount. It wouldn't be noticeable if that sticker wasn't there.
#22 KennyP ONLINE
  • 38,361 Thanks
  • 45,927 posts
Posted March 31, 2013 - 09:05 AM
Looks like it is going good. I'm not sure on a 1650 where the lift bar hooks up.
#23 olcowhand ONLINE
  • 41,167 Thanks
  • 31,423 posts
Posted March 31, 2013 - 09:19 AM
From what I can see, the welds should hold David.  Having never owned that model, I can't say where the lift rod attaches.
#24 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted March 31, 2013 - 10:59 AM
Thanks.
#25 olcowhand ONLINE
  • 41,167 Thanks
  • 31,423 posts
Posted March 31, 2013 - 11:14 AM
OK, with that pic I can safely say your welds are gonna hold just fine!  Nice bead!
#26 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted March 31, 2013 - 11:21 AM
She's old but good. I got the pins mounted. I went with cat 0 since I may come across some correct arms at some point. After lunch is rock shaft time.
#27 olcowhand ONLINE
  • 41,167 Thanks
  • 31,423 posts
Posted March 31, 2013 - 11:44 AM
Our farm shop welder is that exact century welder, except we don't have the high frequency adapter like yours has added.  Dad will likely still use ours, but I'll mostly use my Hobart Tigwave 250.  It's AC settings are so much smoother than the Century, but then it's a way more expensive welder from those days.
#28 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted March 31, 2013 - 03:54 PM
I dont use the stabilizer.
Here is what I've got so far. The link that connects to the lift arm is to long and hitting the fender so that's got to be trimmed.
#29 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted March 31, 2013 - 07:29 PM
So I've bitten off more than I can chew. I have limited tools or the ability and the hitch shows it. It's crooked in a few different ways. I got the lift rod threaded and ends put on. I bolted everything back up. All I have to do tomorrow is install the lower arms and do I full test.
  • twostep said thank you
#30 olcowhand ONLINE
  • 41,167 Thanks
  • 31,423 posts
Posted March 31, 2013 - 07:34 PM
A little crooked in a few places doesn't matter as long as it works.   :thumbs:
