Going To Build A 3ph For My 1650
39 replies to this topic
#1 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted March 18, 2013 - 08:50 AM
My goodness cub guys think a lot of there hitches. I can't find one that's affordable. I looked at the extreme motor works version. Certainly a nice hitch but I just can't bite that 500$ bullet. Especially when I've got a few fabrication skills. You know is gotten to the point that hitch parts are even high. As of right now this is the most favorite tractor I've had so hopefully I can make this functional and cosmetically awesome. I won a complete hitch setup off a allis 5010 from Joes outdoor power. I think it will be a good start. Pics to follow OHD the parts arrive.
Sent from my HTC One VX using Tapatalk 2
  • HowardsMF155, CRFarnsworth and twostep have said thanks
#2 HowardsMF155 ONLINE
  • 2,861 Thanks
  • 2,987 posts
Posted March 18, 2013 - 09:10 AM
Looking forward to seeing what you fab up.
#3 olcowhand ONLINE
  • 41,052 Thanks
  • 31,392 posts
Posted March 18, 2013 - 01:28 PM
Take your time, wet as it is, it'll likely be Fall before you can make a plow day....but then you'll be putting out a garden likely.
#4 CRFarnsworth OFFLINE
CRFarnsworth
  • 4,664 Thanks
  • 2,140 posts
Posted March 18, 2013 - 04:26 PM
Look forward to the build and pictures.  Rick
#5 farmerall ONLINE
farmerall
  • 2,204 Thanks
  • 1,474 posts
Posted March 18, 2013 - 04:33 PM
Looking forward to see hwo you build it and how it works when you are done.
#6 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted March 18, 2013 - 07:00 PM
Hitch was shipped today. I have some ideas but it's hard to brain storm without the parts.
#7 twostep OFFLINE
twostep
    Rockstar
  • 1,983 Thanks
  • 2,534 posts
Posted March 18, 2013 - 09:51 PM
:wewantpics:  I might be following right behind you so document it well!
  • backwoods said thank you
#8 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted March 19, 2013 - 01:55 PM
ive been want to build one myself maybe watching a build on one might get me moving on building mine
#9 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted March 21, 2013 - 06:21 PM
Look what was by the door when I got home. Hopefully after my son goes to bed I can get to the shop and get it all unpacked.
#10 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted March 21, 2013 - 07:08 PM
Box #1
A sleeve hitch adapter. It seems small but might be right for a cat0. I could make one for less than I paid I'm sure but I dont have a welder here and I need to get this done asap.
  • twostep said thank you
#11 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted March 21, 2013 - 07:14 PM
Box #2 the hitch. I could have sworn I had a rock shaft with this kit. I didn't so that's not good. I choose this one because it is cat1. Is easier to adapt down then to adapt up. I laid it out just to see. The arms are long so I'm not sure if I am going to shorten them or try to tuck them under the tractor. I don't think it would hurt anything to have them 20" behind the tractor, well except for center of gravity. I can't believe I dont have the rock shaft. I have no idea why the pictures look flushed.
#12 56series OFFLINE
56series
  • 31 Thanks
  • 31 posts
Posted March 21, 2013 - 08:37 PM
Can I ask what are your plans for this tractor?
Thanks
Jason
#13 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted March 22, 2013 - 05:02 AM
Ground engaging equipment and pulling stuff around the yard. This gal will probably never mow.
  • 56series said thank you
#14 twostep OFFLINE
twostep
    Rockstar
  • 1,983 Thanks
  • 2,534 posts
Posted March 22, 2013 - 07:54 AM
Box #1
You're right, they are cheaper to build that looks nice.
#15 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted March 24, 2013 - 03:46 PM
If I leave the arms the length they are this is how far they will stick out behind the tractor. Seems a little far. I've decide to build a sub frame that comes from the axle up the back of the tractor to the top of the seat pan. I think that will be the easiest way to mount everything with out disturbing to much of the tractor.
