Massey Mf12 With Compressor On Front, Pictures ?
52 replies to this topic
#16 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted March 21, 2013 - 06:45 AM
I decided to build one.
In the one shed, I found a good tank.
And in another shed, I found an old compressor, which
I tested, and it works good.
It's an old DeVilbiss. That rectangular cap, above the crankshaft bearing, is
where you add oil. It flips up.
I've got the frame welded up, tank modified with mounting brackets, and an
unloader valve on order.
Next, will be the clutch/tensioner and belt guard. I may make it different, so
it covers the engine pto pulley too. That's a nasty pinch point.
  • Alc, KennyP, HowardsMF155 and 2 others have said thanks
#17 KennyP ONLINE
  • 51015 Thanks
  • 52653 posts
Posted March 21, 2013 - 06:49 AM
Looks good, Will! See, that old tractor has come in handy already! You can use it to build things for the pretty ones!
  • IamSherwood said thank you
#18 Cat385B OFFLINE
    Tractorfanatics.com
  • 14749 Thanks
  • 10288 posts
Posted March 21, 2013 - 06:51 AM
If you used swivel fittings on the ends (like through the bung drain opening) it could double as a front-mounted lawn roller with a bit of fab work.
:poke:
#19 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 472 Thanks
  • 1280 posts
Posted March 21, 2013 - 07:02 AM
That will be real handy Will. The area beside the pump could be used for a small reservoir. When connected to a cheap blow-gun with syphon tube attachment*, you can paint, spray insecticide, soap etc--virtually any liquid, where-ever you can drive the tractor.
I cleaned inside my diesel fuel tank with air and syphoned diesel last week. I couldn't remove the tank and didn't want to wash it with soap and water.
* Harbor Freight about $10
  • Alc and IamSherwood have said thanks
#20 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted March 21, 2013 - 07:04 AM
:poke:
Yeah, thaaaat's thinking...... :poke:
But, I could add a "U" shaped pipe fitting thingy, with wee little holes
in it, and use it to blowdry the sidewalk after a rain....
#21 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted March 21, 2013 - 07:06 AM
Great idea!!!!
#22 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted March 21, 2013 - 07:17 AM
Fantastic headway in a very short order.
Amazing.
Also love the fact you have a pic of what you're trying to make taped to the tractor. :D
#23 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 472 Thanks
  • 1280 posts
Posted March 21, 2013 - 07:26 AM
On those upcoming BIG jobs, you can plumb the compressor head to the rear of the tractor and tow a 60 GAL tank.
You'll be spraying weeds, fertilizing and painting the whole neighborhood !!    :D
#24 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted March 21, 2013 - 07:30 AM
That's so I get it right. :D
#25 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted March 21, 2013 - 07:34 AM
I can't wait to mount it on my shiny MF12, throw on the coveralls, and go out and spraypaint my
picket fence white. Ooops, gotta build that fence first.. :D  And bring a drop cloth, to cover the MF12..
#26 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted March 22, 2013 - 08:33 PM
I got all the fab work done.
Tensioner, belt guard.
And I decided to go with the optional front luggage rack.
And everything is primed.
  • MH81, KennyP and ENafziger have said thanks
#27 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted March 22, 2013 - 08:35 PM
What is inside the green box?
Beer cooler?
#28 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted March 22, 2013 - 08:38 PM
Beer cooler?
Man, your good..... :beer:
#29 johndeereelfman OFFLINE
johndeereelfman
  • 5746 Thanks
  • 2611 posts
Posted March 22, 2013 - 08:41 PM
Wow Will, that looks great! Well done. :thumbs: You're quite the fabricator. Too bad you don't live closer, as I could give you a list of things to make for me.
#30 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted March 22, 2013 - 08:43 PM
Where's mine?
