Farm Fresh Implements
6 replies to this topic
#1 Larry S OFFLINE
Larry S
  • 14 Thanks
  • 13 posts
Posted March 16, 2013 - 04:59 PM
Needs a little fabricating to get it to work. Suggestions are encouraged and welcomed!
  • CRFarnsworth, boyscout862, Nato77 and 1 other said thanks
#2 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted March 16, 2013 - 05:48 PM
Now that's a good idea putting a seat on the disc!  :thumbs:
  • larryd and Larry S have said thanks
#3 Gtractor OFFLINE
Gtractor
    G-agressive tractor
  • 9,139 Thanks
  • 4,896 posts
Posted March 16, 2013 - 05:51 PM
I agree!  The disk will work great and all it needs is a longer tongue to get you back from the handlebars a little.  :thumbs:
#4 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted March 16, 2013 - 05:58 PM
Nate, I'm glad you resisted the temptation to say who was to provide the weight on the seat.
Ben W.
#5 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted March 16, 2013 - 06:03 PM
Ben W.
I was going to say why not use the weight you carry around all day instead of lifting weights onto the disc
  • superaben, larryd and Larry S have said thanks
#6 Larry S OFFLINE
Larry S
  • 14 Thanks
  • 13 posts
Posted March 16, 2013 - 08:19 PM
The 220 lbs I put on it, will be more weight than I can put on it with blocks. I hope it's more like 180 by harvest time.:) Any one with any ideas on the blade? I would like to be able to tilt it up and down and side to side. :wave:
  • larryd said thank you
#7 MH81 OFFLINE
Posted March 17, 2013 - 08:15 AM
Left to right shouldn't be a biggie, just imitate the hookup from almost any of the OEM ones... Unless you plan on doing it from the handle bars.
As for tilt, I don't have a great easy idea unless you happen to have an 18" tire around for just one side. :smilewink:
Seriously, if the piece on the back of the blade was round and the end of the push arm was round and just slightly bigger (2 pieces of pipe that would slide inside one another.) then you could drill and pin at several preset angles without getting to complicated. It would give you skew in the few times you needed it... Just make sure to keep it greased in there.
  • Larry S said thank you
