Kohler Motor Size?
13 replies to this topic
#1 Bob IN OFFLINE
Bob IN
  • 1,477 Thanks
  • 676 posts
Posted March 16, 2013 - 03:07 PM
I just picked this kohler motor up. I was curious would anyone know what hp this might be. It has no id tag on it. Also has an odd cast exhaust elbow.
  • larryd said thank you
#2 Ryan313 ONLINE
  • 3,364 Thanks
  • 5,229 posts
Posted March 16, 2013 - 03:14 PM
The elbow sure is unlike any I have seen on a K series! Because of that I am going to guess that it is a 16 HP K341, but I am not sure. I f you want, you could pull the head and measure the bore.
  • larryd and Bob IN have said thanks
#3 chris m ONLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted March 16, 2013 - 03:17 PM
It is either a K241 (10hp) or a K301 (12hp) It has the same generator brackets as a Ford/Jacobsen GT. But it is red and the pulley on the out put shaft looks like maybe it was from a Wheel Horse?
There should be a number stamped on the block somewhere near the PTO pulley. If not then you could pull the head and check the piston bore size.
#4 chris m ONLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted March 16, 2013 - 03:18 PM
LOl we were typing at the same time :D
#5 Ryan313 ONLINE
  • 3,364 Thanks
  • 5,229 posts
Posted March 16, 2013 - 03:22 PM
Yes, but I forgot about the model number being cast in the block! It should be below the crankshaft, maybe it is above it? I can never remember.
#6 poncho62 OFFLINE
poncho62
  • 1,599 Thanks
  • 1,612 posts
Posted March 16, 2013 - 03:29 PM
The 70s K series had the gear starter, whereas this has the starter/generator.....so I woud think its older. I have seen an elbow like that on the K series
#7 Gtractor OFFLINE
Gtractor
    G-agressive tractor
  • 9,112 Thanks
  • 4,883 posts
Posted March 16, 2013 - 03:56 PM
16 Horse Kohlers had 10 head bolts.  10,12, and 14's horse K series had 9 head bolts.
#8 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted March 16, 2013 - 03:59 PM
It is either a K241 (10hp) or a K301 (12hp) It has the same generator brackets as a Ford/Jacobsen GT. ...
It looks like it has a rope pull-start pulley on it, so the S/G may not be original to this engine?
#9 chris m ONLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted March 16, 2013 - 04:09 PM
That's how all my Fords and Jacobsen's are also. I guess they did it just in case you had to start by hand.
  • New.Canadian.DB.Owner and larryd have said thanks
#10 Ryan313 ONLINE
  • 3,364 Thanks
  • 5,229 posts
Posted March 16, 2013 - 04:29 PM
I agree, all of the kohlers I have seen that had that the starter mounted like that had the cut outs so you could pull start it also.
#11 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,605 Thanks
  • 1,306 posts
Posted March 16, 2013 - 07:05 PM
Its not from a Case but Case did use starter-generator K series engines in the 70's.I think in the late 60's to mid 70's they would supply them the way the manufacturer wanted them.
Edited by rustyoldjunk, March 16, 2013 - 07:06 PM.
#12 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted March 16, 2013 - 10:01 PM
Same elbow on my 241AS.
#13 rustyoldjunk OFFLINE
rustyoldjunk
  • 2,605 Thanks
  • 1,306 posts
Posted March 16, 2013 - 11:12 PM
I have seen that style elbow on Kohlers in Cubs.Huh....."Kohlers n Cubs"......sounds like a kids movie. :rolling:
Edited by rustyoldjunk, March 17, 2013 - 12:26 AM.
#14 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted March 17, 2013 - 05:09 AM
My k321 has 9 head bolts and that cast screw in elbow .
larryd
Edited by larryd, March 17, 2013 - 01:04 PM.
