Panzer Specs?
15 replies to this topic
#1 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,843 Thanks
  • 2,336 posts
Posted March 16, 2013 - 01:52 PM
T75 model, I am looking for the weight and overall Dimensions of this GT for a shipping quote. It also has a mowing deck. Any help provided is greatly appreciated. Thank you!
#2 Lmiller3358 ONLINE
Lmiller3358
  • 1,523 Thanks
  • 1,446 posts
Posted March 17, 2013 - 08:48 AM
Titus, if it's running ,load it on your trailer and take it to a local scale, either wiegh it loaded or unloaded first,probably cost you $10 or $15 bucks, I used to know a few scales down that way, is that truck stop still open south of Providence ?
#3 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,843 Thanks
  • 2,336 posts
Posted March 17, 2013 - 09:05 AM
Oh lord, it sure isn't running. I have a couple shipping companies asking because they want exact weight and measurements. I told them I don't know & they don't want to hear it.
#4 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,843 Thanks
  • 2,336 posts
Posted March 17, 2013 - 09:06 AM
The truck stop in West Greenwich? That's about 5 minutes from me, and they are on the verg of closing.
#5 Lmiller3358 ONLINE
Lmiller3358
  • 1,523 Thanks
  • 1,446 posts
Posted March 17, 2013 - 11:36 AM
well, if they have  a scale and u can get it on the trailer thats a start, go get an empty weight , then go back with the tractor
#6 Canawler OFFLINE
Canawler
  • 1,950 Thanks
  • 1,806 posts
Posted March 17, 2013 - 09:37 PM
I just confirmed that the specs you're looking for aren't in the op manual.  The weight is in one of the sales brochures, but unfortunately my only copy is some photos someone took of it for ebay.  I can see the line for the weight but the resolution isn't good enough to be readable.
  • sacsr said thank you
#7 Clint OFFLINE
Clint
  • 428 Thanks
  • 305 posts
Posted March 18, 2013 - 08:19 AM
I have been digging through my papers and have only located info on the T100 and T200 series so far.
The T100 (3 wheels) is 70" in Length, 42" Wide and 590 pounds. 7-16 tires.
The T200 (3 wheels) is 70" in Length, 43" Wide and 610 pounds. 7-16 tires.
The "Rugged" T100 (4 wheels) 76" in Length, 45" Wide and 620 pounds 8-16 tires.
The "Rugged" T200 (4 wheels) 76" in Length, 45" Wide and 640 pounds 8-16 tires.
I am still looking for the T75 specs for you.
#8 Canawler OFFLINE
Canawler
  • 1,950 Thanks
  • 1,806 posts
Posted March 18, 2013 - 12:24 PM
These numbers are for an 1110 Panzer so maybe not directly comparable but they should be really close.
Weight: 660lbs
Length: 62"
Width: 36"
The 1107 is shown as weighing 540lbs. I wouldn't think the engine could make that much difference but that's what the sales lit. says.
Fwi - 1012 Meteor (hydro) is shown as weighing 750lbs.
Edited by Canawler, March 18, 2013 - 12:25 PM.
#9 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,843 Thanks
  • 2,336 posts
Posted March 18, 2013 - 05:19 PM
Thank you guys
#10 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted March 19, 2013 - 07:44 AM
Weight: 660lbs
Length: 62"
Width: 36"
dont forget the 1110 has a cast iron motor. electric start, lights, and some other features the 1107 doesnt have
#11 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted March 22, 2013 - 08:13 PM
I'd think the t75 would be comparable to an 1107.
#12 Clint OFFLINE
Clint
  • 428 Thanks
  • 305 posts
Posted April 02, 2013 - 01:24 PM
Hey guys, I found my other manuals. The specs on the T75 are
Model T75 Tractor
Engine- 6 H.P. Engine , "Easy Spin" Recoil Starter, Choke-A-Matic.
Speed Ranges-3 Forward and 1 Reverse.
Type of Drive-No Shift Glidematic Drive.
Rear Tires- 6.00 x 12 full peumatic lawn or lug tread.
Differential-Automobile.
Front Tires-5.30/4.50-6 full pneumatic.
Special Features-
     Positive acition geared steering
     Tool Box-Fenders
     Counterbalanced spring rear lift
     Independent rear wheel brakes
     Parking brake-Shock mounted engine
Weight-540 lbs.
Length-62"
Width-35 1/2"
Model T758ES
All the features of model T75 plus: 8 H.P. Kohler
Electric Starter Generator Engine, key switch.
Weight-600 lbs.
Model T70ESL (The L = Loader)
Engine-7 H.P, Electric Starter Engine, key switch.
Rear Wheels-Dual 6.00-12 lug Trea full
     pneumatic, liquid filled.
Front Wheels-4.80-4.00 x 8 full pneumatic tires,
     roller bearing wheels.
Steering-Positive action geared steering, turns
      90 degree corner in 75" aisles
Speeds-Three forward and reverse.
Type Drive-Single control GlidematicDrive with
     hand or foot control.
Brakes-Independent rear wheel brakes. Parking
     Brake.
Misellaneous features-
     Shock mounted Engine
     Tools Box-Fenders
     Special heavy duty front end
Front End Loader-Hein Werner Hydro-Unit
     combining pump, valve and reservoir. Two heavy
     duty long stroke cylinders. Approcimately 2 1/2
     cubic ft. hopper capacity.
Overall Dimensions-Length 91" Width 46 1/2"
Maximum Height 67" Dumping Height 44"
Weight-1020 lbs.
There is more information in the brochure, but I have to go pick up a David Bradley. I know. I know. It's not a Panzer, but hey I collect a little bit of everything. I'm up to five David Bradleys now. Working on my 6th. Hope the Panzer Brochure info helps!
Edited by Clint, April 03, 2013 - 08:24 AM.
#13 Canawler OFFLINE
Canawler
  • 1,950 Thanks
  • 1,806 posts
Posted April 02, 2013 - 07:24 PM
Wow! I thought those T-70 dimensions were WAY off.... until I noticed that was with a loader. :D
#14 NeedMoreStuf OFFLINE
NeedMoreStuf
  • 72 Thanks
  • 46 posts
Posted May 16, 2014 - 12:23 PM
On your post of the T707esl, the mention of the rear duals being liqued filled, this is mentioned in the manual? and if so I wonder if this was not an option but that all T707esl's had liqued filled rear duals. I just found out yesterday, after removing the rear wheels on mine, that the tires are liqued filled. Which apparently led to one of the wheels being rusted beyond repair.
Patrick
  • panzersarebest said thank you
#15 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 245 posts
Posted May 16, 2014 - 08:18 PM
I got these from a brochure .
Edited by fxrs55, May 16, 2014 - 08:22 PM.
  • Clint said thank you
