Always Something To Fix
10 replies to this topic
#1 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted March 16, 2013 - 10:56 AM
Well up at plow day I lost one of the bolts that holds the S/G on my CC129, the hole finally stripped out.
So today was the day to fix it. I bought a 5/16th Helicoil kit, then had to buy a 21/64th drill bit, and some new bolts.
I removed the S/G and bracket and repaired the stripped out hole, and put it all back on. I was tightening the last bolt in the bracket and I stripped it out. So I ad to removed everything and fix the other hole.
I should have fixed it the first time.
Now on the garden, I have collards to plant.
  • KennyP, bgkid2966, boyscout862 and 1 other said thanks
#2 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted March 16, 2013 - 11:02 AM
It's always something. I love helicoils. I wish I could get in the garden. Still to muddy here.
Sent from my HTC One VX using Tapatalk 2
#3 Newpaws493 OFFLINE
Newpaws493
  • 1,366 Thanks
  • 1,810 posts
Posted March 16, 2013 - 11:08 AM
Just another day closer to your GT, where would we be without the fixins?
Edited by Newpaws493, March 16, 2013 - 12:15 PM.
#4 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted March 16, 2013 - 11:16 AM
With this older stuff, if it isn't one thing it seems to be something else to fix.
Dick
#5 Cat385B ONLINE
    HAZMAT CAT
  • 13,967 Thanks
  • 9,999 posts
Posted March 16, 2013 - 11:32 AM
Lost a spring on the mule drive for the snowblower on the Homelite, bought a replacement, snow melted some and found the original, and now the slightly worn belt won't stay on. I have about had it with the Homelite. Might see a post in the 'what did you do to your gt today' thread about me shooting the damn thing with the .45. And the 30-30. And the 10 gauge.
Oh, and it would not start after sitting for about a week and a half. Crank, crank, crank, battery charger, then starting fluid. I have had it.
:shoot2:       Homelite Snowblower 030.jpg
When the Bolens is done, I'll try that out. If it works, then the Homelite is getting the boot. I'm sick of that darn carb on that Briggs, it's junk.
#6 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted March 16, 2013 - 11:36 AM
Well it least it's purty. My old Cub still has its working clothes on.
#7 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted March 16, 2013 - 11:51 AM
Try not to hit the Vickers!!
Edited by New.Canadian.DB.Owner, March 16, 2013 - 04:00 PM.
  • Cat385B said thank you
#8 wawcub47 OFFLINE
wawcub47
  • 68 Thanks
  • 167 posts
Posted March 16, 2013 - 02:12 PM
Went to use my streatched out cub cadet flat bed. been sittin all winter ,started right up went to put it tn reverse and the clutch rod broke!!Shut it off, turned off the gas,closed the shop doors and went to the house.So much for  today. Think i'll have a cold diet dew andrest a while.
  • Amigatec said thank you
#9 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted March 16, 2013 - 02:25 PM
Well I got quite a few things done today. First I didn't unload the trailer when I got home from Plowday, so the first thing I did was hook it up and head to the car wash. I washed the dirt off the DB, then I unloaded and fixed the CC. Took it back down to the carwash and washed under the tiller. Next I got my Snapper RER out changed the oil, aired up the tires, sharpened the blade and gave it a bath.
So today turned out good.
#10 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted March 16, 2013 - 04:37 PM
What Brigg is on that creature?  Large Flo-jet carburetor?
Ben W.
#11 Cat385B ONLINE
    HAZMAT CAT
  • 13,967 Thanks
  • 9,999 posts
Posted March 16, 2013 - 05:24 PM
Single 16 hp with that idiotic updraft carb. If it's not leaking, that means it's running.
