Massey Ferguson 16 Garden Tractor
6 replies to this topic
#1 gismo OFFLINE
gismo
  • 2 Thanks
  • 14 posts
Posted March 16, 2013 - 05:44 AM
does anyone know if all the mf16 garden tractors were variable speed, or both variable and hydro. There seems to be a lot more mf 12s around.  Here is a photo of a mf 16 for sale in Ontario Canada for $600  good deal ?  Thanks for any input       mf 16 garden tractor.jpg        gismo
Edited by gismo, March 16, 2013 - 05:45 AM.
#2 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted March 16, 2013 - 05:55 AM
I believe all MF14 and MF16 are hydro units
#3 JDBrian OFFLINE
  • 9,613 Thanks
  • 14,144 posts
Posted March 16, 2013 - 07:33 AM
Hard to say if it's a good deal or not from that picture. Duals can put a lot of stress on the rear axles and may end up causing more problems than they are worth in the long run. Generally if it is running and has no major problems it would list for more than 600 here in N.S. It also depends on what attachments come with it.
#4 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1,294 Thanks
  • 1,443 posts
Posted March 16, 2013 - 07:35 AM
Gizmo, The one you have pictured, is a repowered 10. 10's&12's have the engine shafts out to the right side of tractor frame with belt drive. The 14&16 are shaft drive inline to the hydro units. hope this helps Shawn
Edited by tractorgarden, March 16, 2013 - 07:39 AM.
  • CRFarnsworth said thank you
#5 IamSherwood OFFLINE
  • 8,390 Thanks
Posted March 16, 2013 - 07:40 AM
I saw that ad too.
It's a MF10, repowered with a 16hp B&S.
So, it's a gear drive, with variable speed selector.
As said, the 14 and 16, are shaft drive hydro units.
#6 poncho62 ONLINE
poncho62
  • 1,607 Thanks
  • 1,613 posts
Posted March 16, 2013 - 08:32 AM
There were 12hp hydros too, I believe......I may be wrong about that......
Edited by poncho62, March 16, 2013 - 08:33 AM.
#7 IamSherwood OFFLINE
  • 8,390 Thanks
Posted March 16, 2013 - 08:52 AM
Yes, you're right. It was a belt drive, as Shawn said.
In that series/style, the made the following.
MF7    Gear and Hydro
MF8       "               "
MF10  Gear with variable speed
MF12  Gear and Hydro
All of those where belt drive, and some where only available in certain years.
Some of the 7 and 8s didn't have electric start. Tecumseh engines.
MF14 and 16     Hydro shaft drive. Kohler engines.
This link takes you to the pdf showing production years, and serial #s.
  • MH81 and HowardsMF155 have said thanks
