Steering Sector Seal
10 replies to this topic
#1 willy1094 OFFLINE
willy1094
  • 38 Thanks
  • 72 posts
Posted March 16, 2013 - 03:16 AM
Hello,
I've been looking for this seal.  I'm just sure that there is a seal out there for the steering box/sector.  I've found these two Omix-Ada 18029.03 and 18029.04 but I can't find anyone that lists the I.D. or O.D. of either one.  The .04 looks like the one I took out but that doesn't mean anything.  I'm sorry if I already asked about these but I just thought someone might know about these, or even better, a seal that fits.
Thanks!
#2 boyscout862 ONLINE
  • 12,864 Thanks
  • 9,176 posts
Posted March 16, 2013 - 05:00 AM
A full description and some pictures would help someone here to identify the seal.
#3 Alc ONLINE
  • 6,902 Thanks
  • 7,468 posts
Posted March 16, 2013 - 08:04 AM
I've had good luck with seals and  bearings that had a hard time crossing over by just taking either the old seal to NAPA  or measure all the parts and they came through most of the time , good luck !
#4 pharmer OFFLINE
pharmer
  • 871 Thanks
  • 774 posts
Posted March 16, 2013 - 10:33 AM
You will need the shaft diameter. The bore diameter (in the housing) and the width of the seal. Is this for a Power King?
#5 Ryan313 OFFLINE
  • 3,369 Thanks
  • 5,231 posts
Posted March 16, 2013 - 02:30 PM
The manual has the part number 09-9027 and calls it the "SEAL, Lever shaft." There are no dimensions listed for it.
#6 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted March 16, 2013 - 05:01 PM
Check out this one: http://www.oreillyau...02861&ppt=C0203
  • willy1094 said thank you
#7 willy1094 OFFLINE
willy1094
  • 38 Thanks
  • 72 posts
Posted March 17, 2013 - 12:56 AM
Username, I'll have to check my measurements, but I think that's it!  Thanks!!!!  I took the old one into NAPA and KOI and they both said they could not find a seal that matched.
Edited by willy1094, March 17, 2013 - 12:57 AM.
#8 pharmer OFFLINE
pharmer
  • 871 Thanks
  • 774 posts
Posted March 17, 2013 - 07:43 AM
I'm surprised coulddn't match it. I rebuild steering gears for a living and that is a common seal I use quite a bit. let me know if you can't find one and I'll see what I can do for you.
#9 pharmer OFFLINE
pharmer
  • 871 Thanks
  • 774 posts
Posted March 19, 2013 - 05:42 PM
If you still can't find one PM me your address and I'll mail you one no charge.
#10 willy1094 OFFLINE
willy1094
  • 38 Thanks
  • 72 posts
Posted June 23, 2013 - 02:54 AM
I almost forgot to add that this seal is exactly the one I was looking for.  Sorry it took me so long to do that.
Edited by willy1094, June 23, 2013 - 02:54 AM.
#11 pharmer OFFLINE
pharmer
  • 871 Thanks
  • 774 posts
Posted June 23, 2013 - 10:50 AM
i have a bunch of them if you ever need one again.
