* * * * - 1 votes
Twostep's Jd 140h3
72 replies to this topic
#46 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted March 26, 2013 - 09:21 PM
Been through all of my service manuals, parts manuals, and operators manuals. Nothing describing this hole or what it is for. Heck, some of the pictures in my '68 operators manuals, don't even show the hole there. It wouldn't be for any of the attachments that I would know of, and the rear pto runs off of the same clutch switch as the front pto, so that is out of the question. I still say it was most likely a hole allowed for a cab mounted warning light or even cab mounted headlights, just in case you wanted to keep them independantly wired, and on separate switches just in case you wanted to remove the cab.
  • Texas Deere and Horse and twostep have said thanks
#47 Texas Deere and Horse OFFLINE
  • 14,889 Thanks
  • 15,514 posts
Posted March 26, 2013 - 09:29 PM
Troy, All my 140/120's have the rear PTO running off of the Hydro and not the front PTO. Was this an optional PTO?
#48 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted March 26, 2013 - 09:37 PM
No, you're right Brian. I had a brain fart. The rear pto is always turning, you engage the tiller drive with the tiller engagement lever.
#49 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,539 posts
Posted March 26, 2013 - 09:44 PM
I think he means the electric clutch on the rear PTO is controlled by the same switch as the from PTO.
Greasing the hydro control sounds like a good guess but I guess that isn't right.
Troy,
Do you have the service manual for the pre 30,000 models?
  • Texas Deere and Horse and johndeereelfman have said thanks
#50 Texas Deere and Horse OFFLINE
  • 14,889 Thanks
  • 15,514 posts
Posted March 26, 2013 - 09:46 PM
Thanks Troy, I only asked because you have seen a lot more of the rare options for JD's then I have.
#51 Texas Deere and Horse OFFLINE
  • 14,889 Thanks
  • 15,514 posts
Posted March 26, 2013 - 09:49 PM
Troy,
Bobby , the electric clutch was only offered on the 300 Series and later. The 100 Series turned all the time as long as the Hydro pump was turning as the Rear PTO was coupled to the back of the pump.
  • johndeereelfman and twostep have said thanks
#52 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Troy,
I have service manuals for the 120's and the 140's, but I'll have to check to see if they cover all years and serial numbers. I just assumed they did, and never really looked to see if they are broken down to serial breaks. I'll let you know tomorrow afternoon.
Edited by johndeereelfman, March 26, 2013 - 09:51 PM.
  • twostep said thank you
#53 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,539 posts
Posted March 26, 2013 - 10:00 PM
Thanks, I got one set of the service manuals but they are they are for 30,001 and up. I think most of the info is the same but of course the rear axle items are different. Here are some screenshots from the JD 140 Hyd Op Manual:
#54 Trav1s ONLINE
Trav1s
  • 3,581 Thanks
  • 4,557 posts
Posted March 27, 2013 - 09:09 AM
The second pic of the two is of a later tractor as the engine is painted black.  That change took place in 1970...
Things that make me go "Hmmm...."
#55 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted March 27, 2013 - 11:31 AM
You can also tell that it is a later unit, as the clutch knob was revised to the toggle switch and the PTO light has been discontinued. The hood decals also have the black outline border, rather than the silver outline like used on the earlier 140's.
  • Trav1s and twostep have said thanks
#56 Trav1s ONLINE
Trav1s
  • 3,581 Thanks
  • 4,557 posts
Posted March 27, 2013 - 12:09 PM
The 120 service manual does not have any pics that help with this mystery.  Part of me wonders if this is a hole that could be used to lubricate the hydrostat control handle as that pivot point is located right in line with the hole.  Still got me on this one...
#57 Texas Deere and Horse OFFLINE
  • 14,889 Thanks
  • 15,514 posts
Posted March 27, 2013 - 02:50 PM
I have a 1969 H-3 apart with the same hole. It gives you access to remove the pin that holds Hydro control lever inside the dash to the Hydro Control Shaft that goes thru the dash to the Speed control handle.
  • johndeereelfman, Trav1s and twostep have said thanks
#58 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,539 posts
Posted March 27, 2013 - 03:25 PM
That makes sense. Thanks a bunch!!
#59 Sandburr OFFLINE
Sandburr
  • 35 Thanks
  • 46 posts
Posted April 16, 2013 - 03:58 PM
That's a Patio for sure. Back in the day it wasn't a popular option. Some dealers went so far to paint them green just to get them sold ! Two years ago I found just like yours painted green. Lucky for me no one else there new it was a Patio.  Nice score !
#60 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,539 posts
Posted April 16, 2013 - 05:41 PM
Thanks Sandburr! So far I'm having fun with it! After the garden gets planted I plan to do some work on it.
