The Way Things Go
9 replies to this topic
#1 HANKG ONLINE
HANKG
  • 6,203 Thanks
  • 3,382 posts
Posted March 15, 2013 - 10:14 PM
HI EVERYONE I own seven GTs of various makes and restored four of them. It helps to have a little mechanical ability,but my most valued tool in these restos is my digital camera I take lots of pictures before I start a tear down and it saves a lot of time on the rebuild. Also I use plastic zip lock bags and lable them with its contents and to what part they came from.If possible put the nuts and bolts back in the part you remove, it eliminates alot of guessing. thanks HANKG.
  • Texas Deere and Horse, hamman, CRFarnsworth and 5 others have said thanks
#2 Newpaws493 OFFLINE
Newpaws493
  • 1,365 Thanks
  • 1,810 posts
Posted March 15, 2013 - 10:25 PM
Hi Hank, so where are the :camera: ???
thanks for the tips though, and if I havent done so, Allow me to say:  :welcometogttalk:  and :wewantpics:
(All in fun...) :smilewink:
  • larryd said thank you
#3 jpackard56 OFFLINE
jpackard56
  • 1,837 Thanks
  • 1,434 posts
Yep, I have to agree. As my start to finish times seem to be getting longer on projects the digital camera has been a real life saver several times. Give me an old small block Chevy, Pontiac or Ford out of the sixties or 70's no problem. Look under a GT and start sorting out jack shafts, bushings, etc. now that becomes a whole nother story Thank you digital cameras !!
  • boyscout862 and larryd have said thanks
#4 KennyP ONLINE
  • 37,552 Thanks
  • 45,535 posts
Posted March 16, 2013 - 06:08 AM
Great ideas, Hank! There's been times I wish I had taken pics.
#5 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted March 16, 2013 - 08:05 AM
I've restored a bunch of tractors, farm as well as garden tractors.  I've repaired more than I can count.  But I still get lost unless I have a camera on board.
Plus, it pays off: you can appease the voracious GTTalk appetite for pictures.
Ben W.
#6 KC9KAS OFFLINE
KC9KAS
  • 5,329 Thanks
  • 4,672 posts
Posted March 16, 2013 - 09:06 AM
:welcometogttalk:  You have a very good system, and I wish I would do that before disassembly of things (motorcycle included). Many time there is a loooong time between disassembly & re-assembly and I don't remember what goes where.
I do have a 3" thick shop manual for the M/C, so it usually is by my side when working in it. The GT's however are another story!
#7 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted March 16, 2013 - 10:07 AM
HANKG, that is about the same I do, your suggestions are worth there weight in tractors.
Dick
#8 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,857 Thanks
  • 4,350 posts
Posted March 16, 2013 - 07:40 PM
I started using a digital camera a while back, really helps, and if I get stuck I post a picture for help. As an example, I posted the following for comments before I split the top belt cover on my deck. I even did a photo shop to see what it would look like before I cut it.
  • Newpaws493 and larryd have said thanks
#9 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted March 22, 2013 - 01:41 PM
You can't go Toooooooo wrong with camera and baggies as long you remember to assign the baggies.
larryd
  • Newpaws493 said thank you
#10 Newpaws493 OFFLINE
Newpaws493
  • 1,365 Thanks
  • 1,810 posts
Posted March 22, 2013 - 02:21 PM
and a proper place to store them bags and a post it note to remind you where that was... :smilewink:  :rolling:
