Gas Line Valves-open Or Closed
5 replies to this topic
#1 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted March 15, 2013 - 07:46 PM
On your Garden Tractor do you store it for a given period of time with the gas valve open or closed provided you have a shut off valve. If you don't have one you then have gas sitting in your carb. year long, is that good on the carb. If you have the valve and shut the flow of gas off do you run it until the gas has all burnt up or what.
Dick
Edited by JRJ, March 15, 2013 - 07:48 PM.
#2 Cat385B ONLINE
    Therapy CAT
  • 12,655 Thanks
  • 9,356 posts
Posted March 15, 2013 - 07:55 PM
When I get real fancy, I remove the air cleaner while running, shut off fuel, wait for it to die, then spray with WD40. Drain tank and see ya next year!
In the diesels I use Startron to prevent algae growth in the fuel, and leave it as full as possible.
#3 Jack OFFLINE
Jack
  • 1,187 Thanks
  • 808 posts
Posted March 15, 2013 - 08:14 PM
Dick
Well to put it simply I would say:  Closed, no,and Yes.
#4 ckjakline OFFLINE
ckjakline
  • 1,120 Thanks
  • 1,116 posts
Posted March 15, 2013 - 09:07 PM
I like to close my valves in case a hose or something leaks.Storing for the winter i will shut valve and run tractor until it shuts off.
#5 Ryan313 OFFLINE
  • 3,241 Thanks
  • 5,159 posts
Posted March 15, 2013 - 09:19 PM
Like others I shut off the flow and let it run out if I am storing for any length of time. I also drain gas out of the tank.
#6 boyscout862 ONLINE
  • 10,805 Thanks
  • 8,092 posts
Posted March 15, 2013 - 10:52 PM
I put Marvel Mystery Oil(MMO) in the gas, this coats the fuel system and combustion chamber which will prevent corrosion. If you just park a tractor with the fuel able to run to the carb the gas will evaporate and a"shelac" like substance will gum up the carb over a year or two. I prefer to run the engine out and hand turn the engine until it is on a compression stroke so that the valves are closed.
