Bolens Has Arrived!
#16
OFFLINE
Posted March 17, 2013 - 12:34 PM
#17
OFFLINE
Posted March 17, 2013 - 12:49 PM
#18
OFFLINE
Posted March 17, 2013 - 05:26 PM
The drill post looking part is what the stater gear rides on and it what makes the gear engage the flywheel when you want to start the tractor. I can't say for sure on why you have to tap it but maye you have a loose connection on the iside or maybe the starter is just worn out.
#19
OFFLINE
Posted March 17, 2013 - 05:56 PM
yea, its weird. ill turn key and nothing, tap the starter and it attempts to turn the flywheel, but it onlt did it once,now it just tries but doesnt seem to have enough power to turn the motor over, I charged the battery and it is at full now. will pull the starter and bench test it tomorrow. any suggestions?
#20
OFFLINE
Posted March 18, 2013 - 05:57 PM
you can bench test the starter all day and not figure it out, so first i would when you take it off remove the cover on the back of the starter opposite end from starter gear check the brushes and the two ground wires that go on the studs that hold the cover on these wires may not be getting proper contact for a good ground some of these are under the washer on the stud and if the starter was rebuilt at one time they may not have put them under that stud washer so the quick fix to this is very small lockwashers that just slide over the stud , (i did this with very suprising results ) you put the ground terminals on then the lockwashers then tighten the cover . it cured my problem on my HH160. but you may find that the brushes are worn, burnt, or damaged and need replaced which you can still get brush kits and rebuild it yourself , all the kit is is a fiber plate with the brushes attached to it and 2 wires that get soldered to the power side and the 2 ground wires that go on the studs somewhat simple but can be a to do . I had the same problem for 2 years and finally figured out the whole thing was the 2 ground wires not getting good contact now it starts like new
#21
OFFLINE
Posted March 18, 2013 - 06:53 PM
#22
OFFLINE
Posted March 18, 2013 - 07:04 PM
Before you pull the starter, jump the power straight to the starter terminal from the battery. I am having electrical problems with mine right now, haven't had time to work on it but had the same problem. Tried changing the switch and nothing, tried another solenoid and nothing. I jumped it form the battery to the starter and it fired right up and ran.
- Newpaws493 and Huskyfan have said thanks
#23
OFFLINE
Posted March 18, 2013 - 09:54 PM
- Huskyfan said thank you
#24
OFFLINE
Posted March 18, 2013 - 09:55 PM
#25
OFFLINE
Posted March 18, 2013 - 10:19 PM
Let us know if it works, were is your solenoid located? The wiring on mine is a mess and I don't think it is mounted in the right place.
#26
OFFLINE
Posted March 18, 2013 - 10:47 PM
#27
OFFLINE
Posted May 10, 2013 - 11:20 AM
#28
ONLINE
Posted May 10, 2013 - 05:50 PM
Ouch don't tap on it any more.You'll knock the magnets loose in the inside of it.Sounds like the brushes are hanging up a bit.They may be worn down.
