Getting Close!
108 replies to this topic
#16 farmerall OFFLINE
farmerall
  • 2,202 Thanks
  • 1,473 posts
Posted March 17, 2013 - 04:29 PM
You're making good progress. painting th efront axel white really looks good and makes it stand out. Can't wait to see it done.
  • suburban 12 said thank you
#17 suburban 12 OFFLINE
suburban 12
  • 396 Thanks
  • 325 posts
Posted March 17, 2013 - 08:14 PM
It wasn't easy but I managed to get the back tires washed today. They were a little big for my washtub but I made it work. I got more primer and got my rims most of the way done. I put the clutch peddle put in, also started to get the engine painted today.
  • DougT and KennyP have said thanks
#18 KennyP ONLINE
  • 37,451 Thanks
  • 45,472 posts
Posted March 18, 2013 - 07:14 AM
What did you use on the tires? They look pretty good! So does the rest of you goodies!
#19 suburban 12 OFFLINE
suburban 12
  • 396 Thanks
  • 325 posts
Posted March 18, 2013 - 07:28 AM
I used a combination of oil eater and purple power and wiped it down with my hand. Had a lot of black dirt come off that wouldn't wash off with just water.
#20 KennyP ONLINE
  • 37,451 Thanks
  • 45,472 posts
Posted March 18, 2013 - 07:36 AM
What is oil eater? I thought that was what Purple Power was for?
#21 suburban 12 OFFLINE
suburban 12
  • 396 Thanks
  • 325 posts
Posted March 18, 2013 - 07:45 AM
Oil eater is an industrial degreaser, I don't know were we got it from but it works good. Just don't hover over what ever you just sprayed, the fumes will get you.
  • Texas Deere and Horse, wvbuzzmaster, KennyP and 1 other said thanks
#22 KennyP ONLINE
  • 37,451 Thanks
  • 45,472 posts
Posted March 18, 2013 - 07:51 AM
I found it here:   http://www.oileater....rDegreaser.html
Edit: Found it at O'Reilly's for $12.99 a gallon!
  • Texas Deere and Horse, tractorgarden and suburban 12 have said thanks
#23 suburban 12 OFFLINE
suburban 12
  • 396 Thanks
  • 325 posts
Posted March 18, 2013 - 07:55 AM
I never knew that they had their own site, nice to know for when I run out.
#24 KennyP ONLINE
  • 37,451 Thanks
  • 45,472 posts
Posted March 18, 2013 - 07:59 AM
I found it at several different places. Just Google it.
#25 suburban 12 OFFLINE
suburban 12
  • 396 Thanks
  • 325 posts
Posted March 18, 2013 - 01:25 PM
I figured you could, I mixed the two because I didnt want to completely run out of one of them. Now I just need to clean up bolts, sand my seat and get new pins before I can put everything together.
#26 suburban 12 OFFLINE
suburban 12
  • 396 Thanks
  • 325 posts
Posted March 19, 2013 - 09:12 PM
I wasn't very productive yesterday and only got the seat sanded and stacked my tires in a corner. Tonight, I got the sear spring, hi/lo lever, and transmission mount bolted onto the back. I got the battery tray and gas tank bolted up, and going to start putting together a new wiring harness tomorrow. Making progress were I can wile it is too cold to finish painting.
  • LTD and Newpaws493 have said thanks
#27 MH81 OFFLINE
Posted March 19, 2013 - 10:39 PM
Progress is good. The little things need doing too.
#28 suburban 12 OFFLINE
suburban 12
  • 396 Thanks
  • 325 posts
Posted March 20, 2013 - 07:45 PM
Checking in with tonight's progress, got some major stuff done. I got the fenders and rear hitch plate bolted on, painted all of my bolts that were sanded and already holding stuff together. I got the transmission put under it, didn't get to bolt it on yet, having problems with getting the filler elbow through the frame.
  • DougT, MH81, tractorgarden and 1 other said thanks
#29 suburban 12 OFFLINE
suburban 12
  • 396 Thanks
  • 325 posts
Posted March 22, 2013 - 07:21 PM
I finally got the transmission bolted on today. Bolted the rear rims on to get them out of the way so I could work around the front with the wiring. I have a piece if a rusted bolt stuck on the one side of the voltage regulator. Hopefully tomorrow I will get to Napa to see if they can get me new idler pulleys. I also got a pic of how the engine is looking, got some of the sheet metal and brackets on.
Edited by suburban 12, March 22, 2013 - 07:26 PM.
  • DougT, MH81 and LTD have said thanks
#30 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted March 22, 2013 - 08:12 PM
Looking good!! That is goingto be NICE when it's done. I am doing a senior project for high school also and I will tell you right now, your a heck of a lot further along than I am. I'm still tearing apart!!!
  • MH81 and suburban 12 have said thanks
