* * * * * 2 votes
My 1968 John Deere 110
682 replies to this topic
#106 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted April 09, 2013 - 08:07 AM
I have been looking at deals, but want to finish Grandpas mower first
#107 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,539 posts
Posted April 09, 2013 - 01:47 PM
Fine job! You are making me want to start working on mine. I sure wish I had that hitch!
  • Navy Chief said thank you
#108 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted April 10, 2013 - 08:23 AM
MAde a Dent in her last night, removed corrosion from the new (used) deck lift mechanism primed and painted.
Painted John Deere Green last night, center console, lift mechanism and parts, and started painting frame
Looking good
  • twostep said thank you
#109 Trav1s ONLINE
Trav1s
  • 3,581 Thanks
  • 4,557 posts
Posted April 10, 2013 - 09:03 AM
From the pics I would suggest one more coat of green applied a bit heavier.  The danger in that is too much heavier and you get a run.  HOw many coats?
#110 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted April 10, 2013 - 01:49 PM
first coat
#111 Trav1s ONLINE
Trav1s
  • 3,581 Thanks
  • 4,557 posts
Posted April 10, 2013 - 02:55 PM
More coats will bring additional depth and they will also make the JD green look more green.  I think that is your biggest challenge at point with the paint.
#112 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted April 11, 2013 - 08:07 PM
I was thinking that, the JD green didn't quite look exactly dark enough, today I painted more parts and gave some a 2nd coat
Working on cleaning up the motor now and painting it
Got my JD parts from the dealer but now have to order more that I need
#113 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted April 12, 2013 - 11:27 AM
Painted JD Green, Grill, Oil Nozzle, Breather, some nuts, engine components and put 2nd coat on manual lift mechanism.
Ordered more JD paint 2 cans went fast
#114 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted April 12, 2013 - 08:49 PM
Success today a BIG Accomplishment, after smashing my nail bending it back and cutting my hand I was able to manipulate and install the manual deck lift mechanism it wasnt easy but it works and looks great!!
#115 Trav1s ONLINE
Trav1s
  • 3,581 Thanks
  • 4,557 posts
Posted April 12, 2013 - 09:25 PM
Looking good!  The grill was green?
#116 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted April 13, 2013 - 08:46 PM
Rev the Grill was original green no black under on there, Should it be black?? I found some old brochures one show black?
Two show green
What say You?
Worked on engine cover sanding today and corrosion clean up, worked on fender corrosion also.
Painted engine parts
Slowly painting and putting parts back together, slow process
  • john-deere-lawn-&-garden-tractor-&-equipment-for-1968-brochure-112-110-140-60_300878923485.jpg
Edited by Spain, April 13, 2013 - 08:52 PM.
#117 Trav1s ONLINE
Trav1s
  • 3,581 Thanks
  • 4,557 posts
Posted April 13, 2013 - 09:07 PM
I am wondering if the early machines were green and the later machines were black.  Got no definites on this.  I would do what was original to the machine and in your case green would be my choice.
#118 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted April 14, 2013 - 06:31 PM
Cleaned primed and painted some more engine and engine parts today, hooked up the parking brake spring that I ordered from the JD Junk yard, hope I hooked it up right.
Worked on the fenders some more
#119 KennyP ONLINE
  • 40,978 Thanks
  • 47,148 posts
Posted April 16, 2013 - 01:49 PM
Coming right along there! Looks good!
#120 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted April 19, 2013 - 02:46 PM
Just received my $200.00 order from John Deere Parts and the new cans of JD green can now proceed
