* * * * * 2 votes
My 1968 John Deere 110
680 replies to this topic
#91 Texas Deere and Horse OFFLINE
  • 14,862 Thanks
  • 15,511 posts
Posted April 03, 2013 - 03:37 PM
The JD guy yesterday gave me that same number but he said he needed to know the mower deck size? 42-48- or 54 I was think why did that matter
Each deck has a different location for the driven pulley, so the belts are different lengths.
  • Navy Chief said thank you
#92 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted April 03, 2013 - 04:24 PM
That is the part number according to JDParts for either the 39 or 47 deck.  There are later decks that work on your tractor but we would need the serial number off the deck to confirm which one you have.  I would put my money on the 39 as that is plenty of deck for the k181.
The other variable in this is that the later 110/112 show a longer PTO drive belt than your machine.
Edited by Trav1s, April 03, 2013 - 04:24 PM.
#93 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted April 03, 2013 - 07:09 PM
I measured the deck from side to side its 44 so cut area probably 39, I ordered the belt that you mentioned. Pic attached
Ordered from JD Primary Belt, Secondary Belt, new dash sticker, new key sticker and the free battery kit (hope they give it to me free as the paper says)
Fine sanded again today the console and PRIMED, looks good
You guys look at the mower deck, Grandpa put a piece of sheet metal over the pulley hole?, I don't know why he covered it up, it doesn't look rusted, Okahoma has a bad Mud Dobber problem it could have been that, or maybe the grass debris was getting in there Thoughts? Should I tear this plate off of there?
Edited by Spain, April 03, 2013 - 07:28 PM.
  • Trav1s said thank you
#94 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted April 03, 2013 - 07:12 PM
I would say with 99% certainty this is a Model 39 and it is original.  Some would say they are only original once.  Excited to see your project unfold.
Edited by Trav1s, April 03, 2013 - 07:13 PM.
#95 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted April 03, 2013 - 07:19 PM
Wife bought me a new pressure washer, YEA! Tomorrow Im cleaning the frame
The JD guy was unaware of the FREE battery kit, I ordered it on line and it stated no price information! I wanted him to see the Part Number when he orders my other parts so he can order my kit
Edited by Spain, April 03, 2013 - 07:22 PM.
#96 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted April 04, 2013 - 06:57 PM
Deep cleaned the frame today and transmission, she looks good
  • Trav1s and dropped82 have said thanks
#97 dropped82 ONLINE
dropped82
    Nut Case
  • 2,643 Thanks
  • 1,875 posts
Posted April 04, 2013 - 08:46 PM
Very nice work! I also see you have the integral sleeve hitch. That's a huge bonus. They are getting tough to find. Your coming right along. Almost ready for another!
Eric
Sent from my XT897 using Tapatalk 2
#98 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted April 04, 2013 - 10:40 PM
Dropped82 whats that integral sleeve hitch for?
#99 dropped82 ONLINE
dropped82
    Nut Case
  • 2,643 Thanks
  • 1,875 posts
Posted April 05, 2013 - 08:27 PM
Brinly sleeve hitch attachments. Like a single bottom plow, disc harrow, cultivator, etc. It enables you to attach and lift/lower with the lift handle. Those are getting hard to come by and cost around 200 to 250 depending on where you are.
Eric
#100 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted April 05, 2013 - 09:11 PM
Today sanded corrosion out of the frame areas, have some more to do tomorrow, then prime and wet sand.
#101 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted April 06, 2013 - 07:26 PM
Saturday log spent probably six hours wet sanding and priming, man IM tired. Was able to get the wire wheel marks out by the wet sanding, first I used fine 120 then smoothed it with 1000. Also I removed the instrument panel sticker and ignition sticker. Also removed the seat and started removing the corrosion from the fender.
  • Trav1s and twostep have said thanks
#102 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted April 06, 2013 - 07:51 PM
Looking really nice.  The red oxide primer is really hard to sand so I can see why you are tired.  You are doing this machine proud.  :good_job:
#103 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted April 07, 2013 - 08:30 PM
Today did a lot of other required spring cleaning around the house, but did sand some more on the fender, removed instruction placard, man that thing was super glued on there, painted shifter plate black looks sharp
Tomorrow my manual lift an Deere parts are suppose to be here UPS, the fun begins
#104 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted April 08, 2013 - 07:41 PM
Today I received my parts from Roy at the NY Deere Salvage, cleaned off rust on lift mechanism and cleaned out grease zerts and primed, I have a winner the SPRING mechanism works great. I also purchased a mower deck arm and a PArking brake spring and 2 PTO cover brackets.
Sanded primed and painted shifter plate
Next I have to spray the JD Green then install the lift.
Edited by Spain, April 08, 2013 - 07:41 PM.
  • twostep said thank you
#105 dropped82 ONLINE
dropped82
    Nut Case
  • 2,643 Thanks
  • 1,875 posts
Posted April 08, 2013 - 08:26 PM
Your doing a great job. It seems by your determination the tractor bug has taken root. Have you eyeballed anymore yet?
Eric
