* * * * * 2 votes
My 1968 John Deere 110
680 replies to this topic
#76 Trav1s ONLINE
Trav1s
  • 3,521 Thanks
  • 4,498 posts
Posted March 30, 2013 - 08:20 AM
What was wrong with the lift assembly again??
#77 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted March 30, 2013 - 12:28 PM
Spring would not retract the arm into the groove to lock it at different settings, it would just come out and go side ways and not latch, Grandpa had it made to go full up with the handle locking into a piece of angle iron. I ordered a new arm and mechanism used on ebay
PAIN in the BUTT dont Rccm replacing to annoyone
Edited by Spain, March 30, 2013 - 12:29 PM.
#78 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted March 30, 2013 - 05:14 PM
Did corrosion work sanding and priming work today, Battery Box, Steering column and gas tank straps.
That battery pan was super rusted got it cleaned and the wire wheel also ran across my thumb and burnt it OUCH!
Edited by Spain, March 31, 2013 - 02:12 PM.
  • Trav1s said thank you
#79 Trav1s ONLINE
Trav1s
  • 3,521 Thanks
  • 4,498 posts
Posted March 30, 2013 - 05:41 PM
Check out my 120 thread if you want some info on the process I used.  Glad to hear you are moving along fairly well.
#80 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted March 31, 2013 - 09:19 AM
Right rear axle leaked fluid when I had the tractor jacked up on one side, I guess I will need a new seal
New used manual lift is on its way , from a Deere scrap parts yard, he says its in good shape and works, lets hope so. I also ordered some other parts from him, he has all kinds of other models, not too many 110's, nice guy knowledgeable on how to fix the tractors and friendly and gave me good advice.  "Roy Parker" ;kparker at stny dot com
Roy found the parking brake spring for me, the mower deck arm and pin, the PTO cover mounting brackets and the fender shock absorbers, plus the 11o manual lift assy
Edited by Texas Deere and Horse, April 03, 2013 - 03:35 PM.
#81 Trav1s ONLINE
Trav1s
  • 3,521 Thanks
  • 4,498 posts
Posted March 31, 2013 - 01:02 PM
Looking good so far!  :thumbs:
BTW... the decals for your tractor are available from Deere.  The dash decal part number is M43045.
Edited by Trav1s, March 31, 2013 - 01:06 PM.
  • Navy Chief said thank you
#82 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted March 31, 2013 - 02:10 PM
Trav1s how do you get the old decals off with your wire grinder?
#83 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted March 31, 2013 - 02:24 PM
All Trav1's restore project on his has led me to want to go into mine deeper than previously planned
#84 Trav1s ONLINE
Trav1s
  • 3,521 Thanks
  • 4,498 posts
Posted March 31, 2013 - 08:18 PM
I will send you an email with details but I simply used a razor blade to remove the decals and then used a decal adhesive remove from Napa (forget the brand).  It was pretty straight forward.
#85 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted April 01, 2013 - 07:10 PM
Spent the whole afternoon after work removing the tower and instruments and levers and started corrosion work on the inside of that. Painted steering column. I hope I remember were everything went!!!!
Going to make a trip to John Deere to make sure that  I order the right Dash sticker and I have to order new belts
Im sanding and priming now it wont be long till I start blasting her with JD Green
Edited by Spain, April 01, 2013 - 07:16 PM.
#86 KennyP ONLINE
  • 40,170 Thanks
  • 46,778 posts
Posted April 02, 2013 - 07:49 AM
Have a blast. Going back together can be challenging!
#87 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted April 02, 2013 - 07:35 PM
Worked all afternoon on sanding the corrosion out of the console, had more rust than I thought, Im still working it but it looks a lot better
Edited by Spain, April 02, 2013 - 08:10 PM.
#88 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted April 02, 2013 - 11:25 PM
Anyone know the John Deere part number for the belt that goes from the tractor PTO to the mower deck?
#89 Trav1s ONLINE
Trav1s
  • 3,521 Thanks
  • 4,498 posts
Posted April 03, 2013 - 11:09 AM
Here is a great reference tool that will help you figure out all the various part numbers.  Go to www.jdparts.com, select Parts catalog search then  search for your model number "110" and select serial numbers 100,001 and up. I Found this number under the attachment section for tractors up to serial number 176558 = M45998
#90 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted April 03, 2013 - 12:14 PM
The JD guy yesterday gave me that same number but he said he needed to know the mower deck size? 42-48- or 54 I was think why did that matter
