* * * * * 2 votes
My 1968 John Deere 110
678 replies to this topic
#661 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted November 06, 2017 - 12:13 PM
how are you liking your new house?
  • Navy Chief said thank you
#662 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted November 13, 2017 - 06:15 PM
VEry Nice
#663 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted November 13, 2017 - 11:22 PM
You got any picture of it.
You can take a picture with your 110 in front of your house
thanks
Lyall
#664 Richone OFFLINE
Richone
  • 2 Thanks
  • 2 posts
Posted December 16, 2017 - 05:58 PM
I have a old John deer was wanting to find out what exactly I have
#665 Richone OFFLINE
Richone
  • 2 Thanks
  • 2 posts
Posted December 16, 2017 - 06:03 PM
  • Z71 Sierra said thank you
#666 Leonard VanCamp ONLINE
Leonard VanCamp
  • 510 Thanks
  • 390 posts
Posted December 16, 2017 - 06:50 PM
If you can clean up the ID tag I can look up the serial number.
#667 JD318420 OFFLINE
JD318420
  • 65 Thanks
  • 97 posts
Posted December 16, 2017 - 09:35 PM
Square fender 110. Serial number will help find year.
#668 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted January 08, 2018 - 09:25 AM
Finally got the John Deere started for a winter yard clean up, he Putted and Died alot, finally ran almost ok, then it sheared the outside PTO bolt that goes to the mower engagement arm.  I think its item 20.
I think the gas went bad has alot of cream sediment in the bowl, Im going to have to drain the tank ran really bad.
Happy New Year All
Edited by Navy Chief, January 08, 2018 - 09:32 AM.
#669 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted January 08, 2018 - 09:38 AM
Happy New Year All
At lest you have the bolt sizes in that PDF. Should be easy enough to replace. May have to go to a 1/4" longer bolt. I get a grade 5 or better for replacement.
#670 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted January 08, 2018 - 10:40 AM
It has a weird head not normal bolt
#671 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted January 08, 2018 - 11:08 AM
That is an odd head.
#672 secondtry OFFLINE
secondtry
  • 1,882 Thanks
  • 1,380 posts
Posted January 08, 2018 - 11:21 AM
   When I brought home my 112 as a basket case that bolt was missing. Having never seen it and having never seen the clutch in action It took some thought to make something work. I don't remember exactly what I did but I seem to remember double nuts, a longer bolt and some fancy grinding/ filing. If I remember correctly I considered it important to modify the bolt and nut combination and leave all the existing  parts alone. Thinking the John Deere parts are expensive but I can pick up another generic bolt cheep. I will attempt to get pictures and a better explanation of my solution later. Don
#673 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted January 08, 2018 - 12:09 PM
John
The bolt #20 and the bolt you posted a pic of do not like the same.
Is the bolt you have is the one that bolts to the frame?
it looks like part #24 to bolt part #23 to the frame.  Which there should 2 bolts for that.
#674 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted January 09, 2018 - 07:01 PM
Goes on the end of that PTO arm to pull the arm down to engage the PTO, Also the parts manual says the one bolt like mine is no linger avaiable I think they replaced it with the spring one for the vibration there, probaly why mine broke
#675 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted January 09, 2018 - 07:05 PM
This picture is of my PTO arm and that bolt with nuts can be seen at the end of the arm before it broke
