* * * * * 2 votes
My 1968 John Deere 110
679 replies to this topic
#601 lyall ONLINE
lyall
  • 2,170 Thanks
  • 1,573 posts
Posted May 01, 2015 - 08:53 PM
Spain
Did you clean the connectors that come from the Stator?
It is a three wire connection.  Two wires from the stator and the other on (middle wire) should go to the points.
To clean the wire connector you have to remove them from the holder.
A very small screw driver flat blade or a nail that has been flatten, will help remove the wires from the holder.
Rusty wire connection always cause problems
Vaseline or Dielectric grease can be used to help the connection from rusting.
Watch the following video
https://www.youtube....h?v=pC2HVoHWNLA
  • Navy Chief and tomgo1 have said thanks
#602 Navy Chief ONLINE
Navy Chief
  • 158 Thanks
  • 422 posts
Posted May 04, 2015 - 09:39 PM
Travis:
  • lyall and Trav1s have said thanks
#603 Navy Chief ONLINE
Navy Chief
  • 158 Thanks
  • 422 posts
Posted May 13, 2015 - 09:22 PM
Found out why I wasn't getting gas, the tank developed a pin hole and it all leaked out in the garage, ate up my paint job also. Now I will have to JB weld it and repaint the area
#604 Navy Chief ONLINE
Navy Chief
  • 158 Thanks
  • 422 posts
Posted July 13, 2015 - 10:09 PM
Tore Gas tank off this past weekend repaired pin hole, reinstalled, cleaned gas lines and tractor bowl filter, started first time runs great
  • Trav1s said thank you
#605 Navy Chief ONLINE
Navy Chief
  • 158 Thanks
  • 422 posts
Posted December 07, 2015 - 10:34 PM
Hey all, Ive been extremely busy working at the house after a Tornado tore up the place, just got finished replacing the fence and sod in the yard. The JD still starts up and runs great
  • lyall, KennyP, Trav1s and 1 other said thanks
#606 lyall ONLINE
lyall
  • 2,170 Thanks
  • 1,573 posts
Posted December 07, 2015 - 11:49 PM
Glad you are okay - sorry about the Tornado
been wondering what you were up too
miss you
  • Navy Chief said thank you
#607 KennyP OFFLINE
  • 40,045 Thanks
  • 46,732 posts
Posted December 08, 2015 - 06:31 AM
Glad you made it through. Hope not much damage to things.
#608 Trav1s ONLINE
Trav1s
  • 3,513 Thanks
  • 4,494 posts
Posted December 08, 2015 - 03:45 PM
Glad to hear no-one got hurt in the tornado.
#609 Navy Chief ONLINE
Navy Chief
  • 158 Thanks
  • 422 posts
Posted February 06, 2016 - 01:57 AM
Pulled out JD to mow the yard, tried to start engine it  was making loud bangs like metal on metal, engine cover was shaking, tore off cover the starter cog and nut had came off, got another nut put back to gather greased and mowed yard, I hope that nut doesnt come off again from that starter, besides that it fired right up
#610 Navy Chief ONLINE
Navy Chief
  • 158 Thanks
  • 422 posts
Posted April 18, 2016 - 09:04 AM
MOwed again worked great, had one grease drip from rear axle hub
  • lyall and SupplySergeant have said thanks
#611 lyall ONLINE
lyall
  • 2,170 Thanks
  • 1,573 posts
Posted April 19, 2016 - 08:16 PM
hope you are dry.
seen Houston area gas been getting a lot of rain.
#612 Navy Chief ONLINE
Navy Chief
  • 158 Thanks
  • 422 posts
Posted June 06, 2016 - 11:12 PM
Tractor has been working great, I mow yard fairly quick in 4th gear.
HOWEVER today I had almost finished the mowing and the engine did several pops, and then sputtered and stopped, it would not restart.
I spun the flywheel doesn't seem to have a lot of resistance as I turn it over I do feel some pressure air coming from the spark plug hole
Don't know whats wrong, maybe valves?
I checked the gas removed fuel line getting some flow, I will clean out the bowl and ensure that its free flowing
Any suggestions
THanks all John
#613 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,921 Thanks
  • 1,062 posts
Posted June 06, 2016 - 11:22 PM
That's what my 140 did at Daniels plow day, turned out to be a bad condenser. Of course, in fixing that, I discovered that I was running the wrong coil, .5 ohms instead of 3-6.... got it all sorted out now. Good luck!
#614 Navy Chief ONLINE
Navy Chief
  • 158 Thanks
  • 422 posts
Posted June 07, 2016 - 04:34 PM
I have the new JD condesor installed, but the coil is old, I will try all of that
#615 Navy Chief ONLINE
Navy Chief
  • 158 Thanks
  • 422 posts
Posted June 12, 2016 - 09:29 PM
Ok all, I did some trouble shooting.
1. Ignition Spark is good about knock my hand out of the pliers
2. Gas tank filter had alot of micro crap in it
3. Inline gas filter had alot of miro crap in it
4. Gas flow from hose was minimal
5' Carb probably has the same crap in it
Cleaned it all up, went to start and now the battery is dead
Dont know if its from my constant cranking or if the battery is not being recharge, will put a charger on it
  • SupplySergeant said thank you
