* * * * * 2 votes
My 1968 John Deere 110
678 replies to this topic
#571 Trav1s ONLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted October 08, 2014 - 03:14 PM
Good news!  Going out priority mail today.
  • Navy Chief and CharlesDes have said thanks
#572 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted October 10, 2014 - 08:05 PM
Got the mower wheel today it works great!! Better than my old one. I would like to have the other one too if you could part with it?
The Tractor ran awesome
I still have the issue of when I mow THICK saint Augustine the mower blades stop, when set on med or lower setting, at next to high or high setting its fine, I adjusted the belt adjustment knob all the way tight!! Any suggestions, I have all the correct belts installed
Grandpa had a big washer installed under one of those pulleys I wonder if that was there to make the belt more taunt?
If it was berrmuda it would be no problem its the saint augustine
#573 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted October 10, 2014 - 11:46 PM
the washer should ride on the inner bearing race and not touching the pulley housing or the out bearing race.
part #11 is a thick washer or spacer - it rides on the inner race of the bearing
  • Navy Chief said thank you
#574 Trav1s ONLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted October 11, 2014 - 08:49 AM
I looked for another wheel in my parts stash yesterday and that is the only one that I have.  If I by chance find one I will send it your way.  Glad to hear that you are making progress with the 110.
#575 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted October 11, 2014 - 05:54 PM
Anybody have this issue? I don't think it should do this?
I still have the issue of when I mow THICK saint Augustine grass the mower blades stop when set on med or lower setting , I don't know if the mower belt is slipping to the PTO or the mower deck stops!! Stops, when set to high or high setting mower its fine, I adjusted the belt adjustment knob on the front all the way tight!! Any suggestions, I have all the correct belts installed. Doesn't matter what gear still stops when thick grass cut.
The pulleys are installed per the Deere Manual See attached pic
Grandpa had an extra big washer installed under the upper middle pulley raising that pulley up (Don't know why)
Should I sand down the inside of the pulleys as Lyall suggested  Im confused!! Maybe this thing wont cut thick Saint Augustine? cuts great where its not thick
Could it be a PTO issue?
I wish I could fix this issue
One more issue my gear shift makes grinding noise sometimes when shifting gears, other times it works, can I adjust clutch?
Edited by Spain, October 11, 2014 - 06:14 PM.
#576 Trav1s ONLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted October 11, 2014 - 06:48 PM
The only thing I can think of at this point is the PTO clutch on the tractor.  Did you check it out?
Edited by Trav1s, October 11, 2014 - 06:49 PM.
#577 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted October 11, 2014 - 07:04 PM
Spain
did you cleaned the PTO lining?
part #14
if you have not cleaned the PTO lining, that might be one of your problems
if the PTO lining is glazed over the PTO will slip under heavy loads
what I do is use a rasp file just to rough up the lining to remove the glazing problem
I do mine about every 5 years
also grease the needle bearings (part # 7) in the PTO and make sure that no grease or oil can get to the lining
  • Trav1s and Navy Chief have said thanks
#578 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted October 11, 2014 - 11:25 PM
Havent done that, I have to figure out how to dismantle that, Do you have the manual section on it? Is the lining the inside of #14?
Edited by Spain, October 11, 2014 - 11:27 PM.
#579 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted October 12, 2014 - 06:07 PM
Yes
#580 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted December 25, 2014 - 08:59 PM
Merry Christmas all!!! I haven't done anything but start the tractor I went to Australia for work. My son gave me a John Deere hat and sign for Christmas.
I went to buy the HAPCO seat it was $150.00 now its back up to $200.00 Im disappointed.
#581 Trav1s ONLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted December 28, 2014 - 09:21 AM
Bummer on the seats... I think that price was the end of the year
#582 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted December 28, 2014 - 03:12 PM
Maybe they will lower it again
#583 Nxt2doc OFFLINE
Nxt2doc
  • 628 Thanks
  • 334 posts
Posted January 20, 2015 - 11:09 AM
Just finished strolling your thread here. You have done some really nice work. It gives me inspiration for my 1971 112 that I am starting. Although I have no intentions of the just off the factory line type restoration you are so skillfully working on, but old Henry should be a lot of fun for me. Thanks for the great read.
#584 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted March 27, 2015 - 09:30 PM
Believe it or not its a work in progress always, But fun
#585 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Hey All Im back its about time to push the Deere out and fire him up again
  • Trav1s said thank you
