* * * * * 2 votes
My 1968 John Deere 110
680 replies to this topic
#541 Trav1s OFFLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted May 02, 2014 - 10:31 PM
I will keep that in mind as I tear into it. Nice work!
  • Navy Chief said thank you
#542 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted May 03, 2014 - 06:38 PM
Lyall I guess I should let you since Ive had so many problems with this one "YES"
Give me your address Ill mail you the $
PS I will draw a diagram of how its wired
Edited by Spain, May 03, 2014 - 08:57 PM.
#543 lyall OFFLINE
lyall
  • 2,171 Thanks
  • 1,573 posts
Posted May 03, 2014 - 09:02 PM
Spain just sent you a PM
#544 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted July 16, 2014 - 08:47 PM
Hi All in John Deere land. Ive been busy with work and my son got married in the Dominican Republic on the beach
  • Trav1s and SupplySergeant have said thanks
#545 lyall OFFLINE
lyall
  • 2,171 Thanks
  • 1,573 posts
Posted July 16, 2014 - 08:59 PM
Glad to have you back
I was wondering what happen to you
How is the 110 running?
  • Trav1s, Navy Chief and Gabriel have said thanks
#546 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted July 20, 2014 - 09:31 PM
  • RUNNING GREAT FIRED IT UP FIRST TIME TODAY IN A WHILE CRANKED RIGHT UP!!!! IM PROBALY GOING TO GET THAT NEW HAPCO SEAT SOON
  • iM STILL GOING TO EVENTUALLY GET THE HEAD LIGHTS AND TAIL LIGHTS NOW THAT I HAVE THE LYALL WIRING
Edited by Spain, July 20, 2014 - 09:32 PM.
  • lyall, Trav1s and Gabriel have said thanks
#547 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted August 31, 2014 - 12:01 PM
My mower keeps sucking up tons of grass on the flywheel screen when mowing, any suggestions?
#548 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted September 04, 2014 - 09:34 PM
Did some heavy mowing today, the seal on the rear end is still slightly leaking, I guess I will have to fix it in the winter
For some reason when I try to mow in 3rd gear the mower either quits and don't cut or that NAPA belt slips moving faster through the grass, in 2nd gear  it works fine, but I would rather drive faster?? Comments
#549 Texas Deere and Horse OFFLINE
  • 14,862 Thanks
  • 15,511 posts
Posted September 04, 2014 - 09:58 PM
You won't have that issue if you put a JD belt on it as JD uses a special belt that you can't bye anywhere else that I have found and I have searched a lot of belt suppliers.
  • Trav1s and Navy Chief have said thanks
#550 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted September 05, 2014 - 08:09 AM
I originally ordered and installed the correct JD belt per their parts manual that Travis gave me and it was TOO SHORT, I went to the JD dealer and talked to them and they said WOW, didnt provide me with and alternative part number that would fit? Anyone that can help me find a JD number that will fit I would appreciate it, 2nd gear takes too long to mow!!
#551 Trav1s OFFLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted September 05, 2014 - 09:45 AM
I found some info about this and will post it up when Spain gets back to me.  In short, there are multiple varibles to consider when buying belts for these SF tractors which are:
  • Tractor serial number
  • Deck serial number
From what I can tell there are a total of 4 belts that are available for these combos.  To say differently:
  • tractor "a" + deck "a" = belt "w"
  • tractor "a" + deck "b" = belt "x"
  • tractor "b" + deck "a" = belt "y"
  • tractor "b" + deck "b" = belt "z"
More on this when Spain and I figure this out.  I do love a good puzzle.
As for the trouble with the dealer... not to diss on the parts guys but most know how to use a computer but not do the repairs.  Mechanical knowledge does go a long way.
Edited by Trav1s, September 05, 2014 - 10:03 AM.
#552 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted September 05, 2014 - 12:40 PM
Any body have this manual?
John Deere 39" 47" Rotary mower decks Operators manual OM-M48953 Issue J4
HELP!
Im having trouble getting the correct part number belt on the pulleys it appears to be too short of a belt, my deck is a 39" cutting width the part number per JD online M45998
Attached is the pic of the attempted belt install
Travis Here is the original new JD belt Part Number M45998 See Pic TOO SHORT!! Heres my Serial Number to the deck:  Heres the SN
 E0660 SN 111763M
Edited by Spain, September 05, 2014 - 12:49 PM.
#553 Trav1s OFFLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted September 05, 2014 - 01:46 PM
Alright, you made me do it!  I pulled the belt cover off of the 110 deck (serial - 100,670) and the belt on my deck is the same as yours.  The pulleys look to be the same size too.
But there is the deal, the belt you are needing is #22 in the picture attached and the part number is M40223
http://www.greenpart...0223_p_541.html
And specs are as follows from the above link:
Blade to blade
Measures:
  • 87.100-inch effective length*
  • 0.500-inch width
The belt you have is from engine to deck and I thought that is the one you are fight this round.  There is one belt used on both early and late 39 decks and that is m40223.
#554 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted September 05, 2014 - 09:42 PM
Awesome, yours still had the Part Number on the belt? Im glad, I will order it  Thanks a million
Heres the other belts that I ordered:
M44121 V-Belt - BELT, SECONDARY 0.64 21.98 USD 21.98 USD 1 M82258 V-Belt - BELT 0.33 18.43 USD 18.43 USD  e 1 M45998 V-Belt - PRIMARY DRIVE V-BELT 0.73 24.20 USD 24.20 USD
Edited by Spain, September 05, 2014 - 10:33 PM.
#555 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted September 05, 2014 - 10:51 PM
I looked at the local dealer web page shows those belts also available, my deck is Part E0660 SN 111763M
Also on the JD parts catalog when you go to my tractor SN bring up implements mounted Mower, the belt PN shows  M40223 or M41960  FOR TRACTORS:
          110-8HP  (S.N. -271000)
          110-10HP (S.N. -284000)
          112-12HP (S.N. -259000)
Travis I looked back on my Page 23 and I had found that Part Number before and never ordered it!!
Edited by Spain, September 06, 2014 - 08:43 AM.
