* * * * * 2 votes
My 1968 John Deere 110
680 replies to this topic
#511 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted January 27, 2014 - 10:48 AM
I will clean it also
#512 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted January 27, 2014 - 07:03 PM
Got it off here's the pictures, nut keeps backing off.
#513 lyall ONLINE
lyall
  • 2,180 Thanks
  • 1,577 posts
Posted January 27, 2014 - 08:49 PM
Spain
I think the thick spacer is put on the wrong way
the recess of the thick spacer goes toward the spring
you should not need the washer
recess on spacer
goes on like this
when it is on the shaft it should look like this
recess the wrong way looks like this
that is the why there is a added washer so that the nut did not go into the recess on yours
It also allows the starter benix to go out farther, cause your problem
I did find a starter for the K181 8hp and while I check it over, the brushes need to be replaced
hope this helps
  • Trav1s and Navy Chief have said thanks
#514 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted January 27, 2014 - 11:22 PM
Looked at starter the recessed spacer is correct into the spring but does have that washer not shown in the Kohlner manual, I will removed it, thats probaly why nut is backing off
#515 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted February 01, 2014 - 10:18 PM
Took apart starter bendix cleaned and lubed with graphite grease, it worked once then bendix jammed again, removed cleaned again applied regular grease its intermediate now works only sometimes, the little jack crew sticks inside that gear appears that some of those threads are a little damaged. Any body have a spare gear and little jack crew?
The engine is again not shutting off, I wonder if I burnt up the ignition switch when I was testing those wires before and smoke checked one of them,
#516 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted February 17, 2014 - 02:44 PM
1.Removed Starter again, DEEP Cleaned it and brushed with tooth brush, I added an "O" ring to the back of the bendix gear cause thats where it keep sticking when the bendix goes all the way back, I applied alot of 3 and 1 oil this time, owners manual said Engine oil, put it back on and it works GREAT!! nice not to hear tha humming!!
2. Ignition wont shut off, If I hol my finger on the key and touch the ignition switxh nut  pushing down on the key it shuts off, something to do  witht he key ignition ground?? Puzzled on that one Advice?
3. Transmission started leaking again a little drippping after I mowed the hole yard, guys I have no choice but to tear it apart.
4. Anyone have a manual section that shows how to adjust mower deck? it appears to be cutting uneven on left side, do I just lower those small wheels/
Edited by Spain, February 17, 2014 - 06:44 PM.
#517 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted February 18, 2014 - 12:23 PM
lyall gave me the mower deck manual, now I can adjust it
#518 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted March 02, 2014 - 10:04 PM
Mowed the yard yesterday sometimes the mower deck quits spinning when I hit high grass, I guess the belt is slipping, I did level the mower deck and adjust the cut, per Lyalls instructions, the deck was way off.
#519 lyall ONLINE
lyall
  • 2,180 Thanks
  • 1,577 posts
Posted March 02, 2014 - 10:34 PM
Spain
have you cleaned the pto?
sometimes the pto lining gets glased over and under heavy loads it slips
you need to clean it - I use a rasp file to clean mine
you just need to remove the glase and rough the lining up
first I would tight up the spring for the belt that goes to the mower desk
if that does not help than clean the pto lining
you might have to replace the spring if the lining is good
if your garden tractor was used just for mower the spring might have stretched
#520 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted March 03, 2014 - 08:45 PM
The nob for the Spring appears really loose will tightened that up first,  still have that NO SHUT off problem, the key actual shocked me this time?? But will shut off if you move the choke on on
#521 lyall ONLINE
lyall
  • 2,180 Thanks
  • 1,577 posts
Posted March 14, 2014 - 03:53 PM
Spain
after mowing for after a half hour is the amp gage still charging  like just after you started
if so I think you have a short someplace in the wiring
you will have to check the wiring with a meter to help find the short  or bare wire someplace
you can also check the switch with the meter to see if that is where it is shorting out
I wish you were closer I would help made a new wiring harness for you
  • Navy Chief said thank you
#522 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted March 20, 2014 - 06:34 PM
Just got back from San Antonio for work again, went to fire up the deere to mow the yard,  the starter made a bang, engine started but then I got all kinds of noise and sparks, I didn't know what was going on I thought the motor was coming apart!!! Took the starter off the starter Bendix gear did the opposite this time it did not disengage the starter gear teeth stayed extended and got worn down against the flywheel, its toast!! The fly wheel teeth got worn a little still look workable, I guess the flywheel teeth are stonger than the bendix gear,
Pissed me off, I have to get a new started now hopefully the flywheel is still good
Edited by Spain, March 20, 2014 - 06:36 PM.
#523 Trav1s ONLINE
Trav1s
  • 3,521 Thanks
  • 4,498 posts
Posted March 20, 2014 - 06:49 PM
I have an extra flywheel on my extra k181 if needed.
#524 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted March 20, 2014 - 08:34 PM
I hope not, they wore a little
#525 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 20, 2014 - 08:44 PM
I don't mean to interrupt you guys but i found something pertaining to the JD round fenders that has me perplexed, figure seeing as a 110 is being restored here somebody might know the answer to my questions.
The link below : http://gardentractor...iew=getlastpost
