* * * * * 2 votes
My 1968 John Deere 110
676 replies to this topic
#496 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 420 posts
Posted January 05, 2014 - 10:26 AM
Last night I stood in awe in the Garage gazing at the John Deere and I felt really proud of how it turned out I'm sure Grandpa Dewey would have loved to see it in this shape.
Thanks again for all who helped me and the advice and pictures I couldnt have done it without you guys.
Heres a pic of the before and after and a pic of me and Grandpa Dewey
  • lyall and Cat385B have said thanks
#497 Cat385B ONLINE
    HAZMAT CAT
  • 13,782 Thanks
  • 9,921 posts
Posted January 05, 2014 - 10:32 AM
Good for another 45 years, well done. :thumbs:
  • Trav1s and Navy Chief have said thanks
#498 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 420 posts
Posted January 05, 2014 - 11:46 AM
Ok Question?
I just noticed in my original photo (attached) that the front tire valve stems were on the inside of the rim? I installed the rims with the stem facing out, I had trouble with one rim rubbing on the axle, I shimmed it with a washer its fine now.
However I looked at Travis tractor pic (Attached)  and his valve stems on the front tires are also on the inside! So I assume that I installed the front tires wrong? Stem goes on the inside? why would they do that? Probaly explains why that one rim was rubbing before on the axle, by the pics it looks like it gives the rims more clearance from the axle.
More work!! I will wait till it gets warm and swap them around.
Also another question the motor sometimes want shut off when you put the key to off, you can hear it change speeds like power goes off but  but it keeps running, if you move the choke to on it shuts off, weird, is my new ignition switch already bad?
Edited by Spain, January 05, 2014 - 12:01 PM.
#499 lyall ONLINE
lyall
  • 2,023 Thanks
  • 1,526 posts
Posted January 05, 2014 - 05:38 PM
Spain
very few have the original tires and seat
your 110 looks GREAT
I know you will keep this tractor for a long time and may be your grandson will have it some day
  • Navy Chief said thank you
#500 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted January 05, 2014 - 11:25 PM
That thing looks GREAT!
 My 140 and all of the brochures I've seen either show the valve stem on the inside or the wheel has a chrome wheel cover... makes me wonder if they valve stem interfered with the cover so they were flipped around.
#501 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 420 posts
Posted January 06, 2014 - 12:26 AM
#502 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 420 posts
Posted January 06, 2014 - 12:27 AM
Ok they are right Travis told me that they have a narrow setting or wide setting, mine is now on narrow which on mine is stem out
#503 Trav1s ONLINE
Trav1s
  • 3,200 Thanks
  • 4,299 posts
Posted January 06, 2014 - 10:14 AM
AWESOME!  Love the before and after shot and appreciate the labor of love in your 110.   :thumbs:  :thumbs:  :thumbs:
#504 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 420 posts
Posted January 21, 2014 - 08:39 PM
Back home from my work trips, fired up the Deere,
Engaged the PTO the mower belt wouldn't spin, adjusted PTO arm it finally engaged had to adjust the carb it pulled the power down with the load killed the engine, finally got it adjusted to handle the strain.
I mowed 2 swipes looked good then it quit working, belt wouldn't move PTO was getting hot, tore the deck off found out the inside belt had came off and went under the stationary pulley, removed pulley it had a big washer under it allowing a gap, looking at the parts break down that washer spacer is not suppose to be on there, I will remove it and try it again another tie.
Axle hasn't leaked for 3 weeks even after I operated it,  today after my drive it leaked again!!  Pisssed me off, cleaned it and its holding again, probably going to have to change that seal
Starter is acting up now, sometimes wont engage and slams pops and other times it just hums
Edited by Spain, January 21, 2014 - 11:25 PM.
#505 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 420 posts
Posted January 22, 2014 - 06:56 PM
1. As stated above I found a spacer on the guide pulley that wasn't called out in parts diagram and my other extra mower deck didn't have it either, this allowed the belt to go under the guide pulley and jam the mower due to the space. I Reinstalled the pulley correctly and installed mower deck. Mower now works awesome I cut the front yard it cuts very even really please, it sure blows around a lot of grass.
2. The starter most of the time just hums I finally got it to crank, I need new starter, any body have one for the 8HP?
3. Transmission was leaking at first didn't leak during the mow, probably going to have to tear it down change seal
  • twostep said thank you
#506 lyall ONLINE
lyall
  • 2,023 Thanks
  • 1,526 posts
Posted January 23, 2014 - 01:53 PM
Spain
I have several starters - I think the starter are about the same for 8  - 16 hp  Kohlers - not for sure
most if them are for 10 hp and larger - will have to check my 110 with a 8 hp
if so it will be cheap plus shipping
does your have the bolts above the starter or below when it is bolted to the motor
my Kohler  K181 - 8 hp has them on above the starter
have you looked at the starter and checker it over
something the starter benix sticks
some use graphic power on the benix so the it spins properly
you might just need a new benix
while you has the starter off and checking it over
you can open it up and clean the insides and the brushes
see the Kohler manual how to make the tool to help hold the brushes it place while putting the starter back together.  it is easy to make
Edited by lyall, January 23, 2014 - 02:58 PM.
#507 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 420 posts
Posted January 23, 2014 - 04:10 PM
Lyall its the solenoid sticker wont come out and engage most of the time, I applied PB rust buster before, worked for awhile I will check the bolt pattern for you.
After getting it started finally I mowed the front yard SO FAR THE TRANMISSION is holding I hope it went back in place or the dirt went out or something
Edited by Spain, January 23, 2014 - 04:12 PM.
#508 Trav1s ONLINE
Trav1s
  • 3,200 Thanks
  • 4,299 posts
Posted January 24, 2014 - 07:50 PM
If you want to open the starter up and see if a simple cleaning would help this link has some good info:
http://www.wheelhors...5-k181-starter/
#509 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 420 posts
Posted January 26, 2014 - 08:06 PM
Removed the starter, that end stop nut has again backed off to the last thread, that's twice, this time it cracked the engine cover when it engages. maybe that's one reason it quit engaging?
#510 Trav1s ONLINE
Trav1s
  • 3,200 Thanks
  • 4,299 posts
Posted January 26, 2014 - 08:51 PM
Likely so.  Consider some Loctite on it and try again.
