* * * * * 2 votes
My 1968 John Deere 110
678 replies to this topic
#481 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted December 26, 2013 - 04:45 PM
Travis has me desiring the Headlights and Taillight's now!! I might save my $ and order the set as a gift to me later!!
  • Trav1s said thank you
#482 Trav1s ONLINE
Trav1s
  • 3,306 Thanks
  • 4,361 posts
Posted December 26, 2013 - 05:40 PM
The tails are easy and cheap from Napa.   :smilewink:   I am still looking for alternative for the headlights.
  • Navy Chief said thank you
#483 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,810 Thanks
  • 1,005 posts
Posted December 26, 2013 - 05:49 PM
Spain you can have the headlights mounts and harness off my 140 for shipping. No panel though, both mine and my son's are broken. I plan to go with googly-eyes like the old 110's and Eggman doesn't want lights. Just let me know!
  • Trav1s and Navy Chief have said thanks
#484 hdg4400 ONLINE
hdg4400
  • 284 Thanks
  • 348 posts
Posted December 26, 2013 - 06:25 PM
Spain:
I wasn't much (if any) of a purist with my previous tractor, a JD 140. I bought 12 volt tractor lights at Northern, a pull switch at NAPA, and wired them into the wiring harness. For the front, I had some "L" brackets from my father-in-law. Here is a picture of the tractor before I sold it.
Harlan
#485 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted December 26, 2013 - 10:11 PM
Spain:
Harlan
I think Grandpa had it like this before because it had an extra 2 hole drilled on both sides I fiberglassed them shut
#486 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted December 26, 2013 - 10:12 PM
Ok, you think the harness is the same? what do you think postage will be, slow rate.
#487 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,810 Thanks
  • 1,005 posts
Posted December 27, 2013 - 08:22 AM
Not sure about the harness, but it's pretty simple. Cheapest rate to Houston is Priority Flat Rate Small box, it'll be $5.80. Just PM me your address if you want them.
#488 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted December 31, 2013 - 12:27 PM
New gear oil held for 1 week I drained it out last night and will add the new gear oil that Lyall Rccm, Im also going to drain the engine and put the 30 Weight in there I finally found it.
  • lyall said thank you
#489 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted December 31, 2013 - 02:07 PM
Spain
glad that it is working for you.
I get my 30 wt motor oil  at a farm supply store in a 2 gallon container for less than $20
#490 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted January 01, 2014 - 08:34 PM
Spain
We will see when I fill it full and drive it around
#491 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted January 04, 2014 - 01:21 PM
Serviced transmission with new oil, changed engine oil, installed mower deck I think the tractor to deck belt is routed wrong doesnt look right, any one have a picture of how it routes?
Drove the tractor around some, having the issue with the tractor ignition not shutting off sometimes, it will shut off if you put on the choke.
Edited by Spain, January 04, 2014 - 09:42 PM.
#492 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted January 04, 2014 - 11:50 PM
Spain
here is the routing for the deck belt
belt length for a 39"  is around 87"
belt length for a 47" is around  102"
Edited by lyall, January 04, 2014 - 11:55 PM.
#493 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted January 05, 2014 - 12:58 AM
I need how the PTO belt hooks from the PTO to the back of the mower deck??
Edited by Spain, January 05, 2014 - 01:01 AM.
#494 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted January 05, 2014 - 09:40 AM
for the right belt length you need to go to Deere
different lengths of belts go on,  you need to have the model and serial number from the tractor and the deck so that Deere can get you the right belt length
#495 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted January 05, 2014 - 10:22 AM
Awesome, I was looking back at my forumn first pages and James Henry sent me this pic along time ago appreciate both of you guys providing it for me, now I see how its routed wrong its on top of the small pulley verse under it.
