* * * * * 2 votes
My 1968 John Deere 110
682 replies to this topic
#466 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted December 21, 2013 - 08:59 PM
Spain
remove the mower deck - first if you have it on - so that you can block the tractor up
remove the shifter ball and the foot peddle/s
remove the fender deck
that way you can get the the 5 bolts for the transaxle to the hitch .
remove the spring for the drive pulley
then you have to remove the pin for the brake
you have to remove the drive belt first - there 3 bolts that hold the pulley to the transaxle. so the the belt come off
then you should block the frame up so that you can remove the transaxle
then you can remove  the the 5 bolts
then the transaxle will come out
PM me you phone number so that I can call you
I wish I would have done this when I had it all tore apart
  • lyall said thank you
#467 lyall ONLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted December 21, 2013 - 09:42 PM
been there
  • Navy Chief said thank you
#468 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted December 22, 2013 - 11:04 PM
Fellow forumn members, worked all day on the Deere.
1. Serviced transmission and cycled it, going to try it as Lyall said with new oil hopefully it will hold, the old oil was nasty like water and had dirt, I will drain this one out to clean it and service it again, cross your fingers!
2. Installed flanges and hood
3. Fixed fuel leak on hose
4. Fixed front tire that was rubbing on axle
5. Touched up paint every where that I damaged
6. Sharpened and installed mower blades
Edited by Spain, December 22, 2013 - 11:13 PM.
  • lyall and Trav1s have said thanks
#469 KennyP ONLINE
  • 40,986 Thanks
  • 47,152 posts
Posted December 23, 2013 - 06:08 AM
Looking good!
#470 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted December 23, 2013 - 09:52 AM
Check Tranny this AM so far so good No Leak with the new oil
#471 Trav1s OFFLINE
Trav1s
  • 3,582 Thanks
  • 4,558 posts
Posted December 23, 2013 - 11:55 AM
Looking good!
:thumbs:  :thumbs:
#472 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted December 23, 2013 - 12:09 PM
:thumbs:  :thumbs:
Travis did you read my message? do you still have the service manual I sent you? I lost mine and need a copy
#473 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted December 23, 2013 - 12:14 PM
Any suggestions on how to adjust the hood, its too far back on the right side instrument panel and theres a gap, don't remember it that way before
#474 Trav1s OFFLINE
Trav1s
  • 3,582 Thanks
  • 4,558 posts
Posted December 23, 2013 - 01:03 PM
I will look for it later today!
#475 lyall ONLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted December 23, 2013 - 02:04 PM
Spain
try adjusting the hood uprights that bolt to the frame and/or the bolts that bolt onto the hood
there are not to many places to make adjustment for the hood
  • hdg4400 and Navy Chief have said thanks
#476 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted December 23, 2013 - 05:56 PM
Spain
it was right before I must have did something different this time. THX
#477 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted December 24, 2013 - 04:18 PM
Merry Christmas
  • dropped82 said thank you
#478 dropped82 ONLINE
dropped82
    Nut Case
  • 2,743 Thanks
  • 1,906 posts
Posted December 25, 2013 - 08:18 AM
Merry Xmas to you also!
Eric
Sent from my SPH-D700 using Tapatalk
#479 Navy Chief OFFLINE
Navy Chief
  • 161 Thanks
  • 423 posts
Posted December 25, 2013 - 08:19 PM
3 days good on the tranny but its not serviced to full, Im going to drain that fluid and put the heavier one in there as Lyall stated
#480 Trav1s OFFLINE
Trav1s
  • 3,582 Thanks
  • 4,558 posts
Posted December 25, 2013 - 08:41 PM
Sent it back this morning!  :thumbs:
