* * * * * 2 votes
My 1968 John Deere 110
680 replies to this topic
#436 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted November 29, 2013 - 12:03 AM
Your oil leak i assume is coming from the governor arm (throttle arm). You can still buy the bushing that the arm protrudes through. The dealer may carry it. If not go to Gardentractorpullingtips.com. They have them.
Eric
Sent from my SPH-D700 using Tapatalk
I tightened the gov nut one flange today, the leak now appears to be coming from the breather cover not sure, I don't see it bubbling by the arm now
  • dropped82 said thank you
#437 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted November 29, 2013 - 12:05 AM
The starter most likely just needs to lubed up. Common problem on the 100/200 series, I had the same problem on my 212. lyall's suggestion in post #433 would be to make sure it doesn't happen ever again.
So just lube the shaft where the cog and spring goes? Will WD-40 work? some forum said that
#438 Cat385B ONLINE
    HAZMAT CAT
  • 14,282 Thanks
  • 10,116 posts
Posted November 29, 2013 - 07:38 AM
WD-40 worked for me for a little bit, it starting sticking again as soon as it sat for an extended time. I used PB Blaster the second time and it never did it again. Hopefully that works for you also, but I think lyall's suggestion would be the most prudent course of action.
  • Navy Chief said thank you
#439 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted November 29, 2013 - 09:56 AM
Ive got PB will try that first
  • Trav1s said thank you
#440 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted November 29, 2013 - 06:42 PM
1. Removed Starter Spring and Gear, Lubed with PB and WD40, Operated the Starter and BAM, Man it works good and it don't make all that noise like it did before, before it sounded like someone hit it with a ball pin hammer.
2. Took Carb Off and Muffler, was able to tighten governor arm nut about 3/4 of a turn, took breather plate off, breather filter is toast really brittle, I need a new one, also would like to change that gasket need a part number for both.
TWO STEPS FORWARD TODAY!!!
Edited by Spain, November 29, 2013 - 06:42 PM.
#441 Trav1s ONLINE
Trav1s
  • 3,521 Thanks
  • 4,498 posts
Posted November 29, 2013 - 07:12 PM
Awesome!  I love steps forward over steps backward.
#442 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted November 29, 2013 - 07:40 PM
I need to order some of this stuff, should I  just change plate gasket  and filter? I didn't see no gasket on the plate
Can anyone tell me if this is the Correct crankcase breather fil
http://www.ebay.com/...=item416270478a
I FOUND THE PARTS LIST, I ORDERED IT http://www.ereplacem...533_107802.html
Edited by Spain, November 29, 2013 - 09:21 PM.
#443 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted November 30, 2013 - 09:21 PM
Tore apart breather the GAsket for the cover was installed wrong top middle was stuck down in breather area bent down, that's why it wasn't sealed, it was also missing the plate gasket. Im going to try to make them both
  • SupplySergeant said thank you
#444 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,965 Thanks
  • 1,075 posts
Posted December 01, 2013 - 11:07 AM
Yeah, mine was installed the same way. It blew tons of oil out the dipstick if you pulled it while the engine was running. I fixed it, now it still blows some, but much less. I think my rings or valves are a little worn. Those gaskets should be easy to make, just make sure you use thick gasket material. The factory ones are thick and stiff. Good Luck!
#445 lyall OFFLINE
lyall
  • 2,179 Thanks
  • 1,577 posts
Posted December 01, 2013 - 10:04 PM
Spain
If you are going to cut gaskets for the breather, be careful not to cover the bottom drain hole in the breather plate
when you put the breather plate back on make sure the drain hole is on the bottom
  • Navy Chief and SupplySergeant have said thanks
#446 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,965 Thanks
  • 1,075 posts
Posted December 01, 2013 - 10:10 PM
:ditto:  I forgot about the drain hole. I got me too.
#447 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted December 02, 2013 - 02:19 PM
Mine doesnt blow no oil but it does move the dip stick up and down sometimes on start up, hopefully I can conquer the gasket issue, I trace dit out last night, I will have to locate that breather hole
#448 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted December 02, 2013 - 07:09 PM
Made the new gaskets looks good, waiting for the breather to come in
#449 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted December 05, 2013 - 05:09 PM
Breather arrived, looks like a piece of scotts brite I wonder If that would have worked? would have been cheaper for sure this one was $5.47 with shipping.
Cant install it now temps dropped way low and I have the Flu now Im out of commission for  awhile
Edited by Spain, December 05, 2013 - 05:11 PM.
#450 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted December 17, 2013 - 08:40 PM
Finished installing breather assembly and new filter and gaskets, reinstalled carb the throttle linkages were crome now they rusted must be weather here. putting motor parts back together. Will crank it up again soon
  • lyall, Trav1s, dropped82 and 1 other said thanks
